updated firmware now problem with stabilize.
I just updated the firmware on my amp 2.5 and now in stabilize mode if i bank the plane right the elevator goes up and if i bank it left the elevator goes down ,the elevator should not even be moving the ailerons should be.
everything is connected correctly and works fine in manual mode and the HUD in mission planer is working correctly showing the plane on a bank but the apm operates the elevator.
I have re calibrated the apm heaps of times but still the same banking operates the elevator and the elevator is connected to output 2?
    Check to make sure you haven't turned on elevon mode by mistake.
    • Checked elevon mode and it is off, reinstalled a previous firmware and works no problems then tried the latest firmware again and same problem as before banking the aircraft makes the elevator go up and down so it looks like i am going to have to run the previous firmware to make it work correctly.
      • I am now using firmware 2.73 tried all the newer versions and they will not work they operate the elevator instead of the ailerons to level the plane,And I have not changed a thing so I will stick with 2.73 for now as I cannot work out why it is doing this?
        • Still no luck with this as I would like to use a newer firmware to use the rally point feature which does not work on 2.73 ,but no matter what I try if I upgrade the firmware elevator works in stead of ailerons to roll plane in stabilize? Yet all works fine in 2.73
