Tags:
it apears to be erroring in the download phase.
there are 2 posible issues.
firstly the comport is in use/not open like it says.
the second is the apm might be browning out. do you have a receiver/servos pluged in. if so please remove them and try again OR power the servo rail, to make sure that a brown out wont occur. Ive added more error message in the next version of tha planner, so can identify where its failing.
Permalink Reply by steve F11music.com on July 4, 2011 at 5:38pm
Permalink Reply by steve F11music.com on July 4, 2011 at 3:01pm
Permalink Reply by steve F11music.com on July 4, 2011 at 4:20pm
Permalink Reply by steve F11music.com on July 4, 2011 at 5:23pm it *should*
you need to goto load the main .exe with mono.
im not sure if it still works or not.
Permalink Reply by steve F11music.com on July 5, 2011 at 8:03am
Permalink Reply by neil.elver on July 5, 2011 at 8:52am I was looking into this a few months ago and at least then there was a confirmed Mono glitch when it comes to Serial ports on OSX and probably Linux. I could never get past that error. Since Mono is an open source copy of .NET it still struggles at the fringes of functionality (like dealing with low level OS access to things like serial, even if it's USB to serial). I bet it's fixed in a future version, but not sure where it is on priority list. here's a real old, slightly related forum I found Googling: http://www.gotmono.com/cgi-bin/yabb/YaBB.pl?num=1115393297
Also, I launched the program in the Terminal - try typing mono (space) and then dragging the file into the terminal windows, which should copy the path to the exe. I think I also could click and drag the .exe to mono somehow too. But the install may be ending up in the hidden 'system' side of things. I've rebuilt that computer since so not sure.
Permalink Reply by neil.elver on July 5, 2011 at 8:58am
Permalink Reply by steve F11music.com on July 5, 2011 at 11:02am I tried opening it with terminal like you said but get a bunch of errors.
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.WindowsFormsSynchronizationContext ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.ThemeEngine ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.ThemeWin32Classic ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.KnownColors ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: /Library/Frameworks/Mono.framework/Versions/2.10.2/lib/libgdiplus.dylib at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&) at System.Drawing.GDIPlus..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at System.Drawing.KnownColors..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at System.Drawing.Color.get_Black () [0x00000] in <filename unknown>:0 at System.Windows.Forms.ThemeWin32Classic..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at System.Windows.Forms.ThemeVisualStyles..ctor () [0x00000] in <filename unknown>:0 at System.Windows.Forms.ThemeEngine..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at System.Windows.Forms.SystemInformation.get_MenuAccessKeysUnderlined () [0x00000] in <filename unknown>:0 at System.Windows.Forms.Control..ctor () [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control:.ctor () at System.Windows.Forms.WindowsFormsSynchronizationContext..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at System.Windows.Forms.Control..ctor () [0x00000] in <filename unknown>:0 at System.Windows.Forms.ScrollableControl..ctor () [0x00000] in <filename unknown>:0 at System.Windows.Forms.ContainerControl..ctor () [0x00000] in <filename unknown>:0 at System.Windows.Forms.Form..ctor () [0x00000] in <filename unknown>:0 at ArdupilotMega.MainV2..ctor () [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) ArdupilotMega.MainV2:.ctor () at ArdupilotMega.Program.Main () [0x00000] in <filename unknown>:0 bash-3.2$
Permalink Reply by neil.elver on July 5, 2011 at 4:13pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
24 members
48 members
51 members
111 members
Powered by
