I am in the process of building an autopilot, and I have a Pololu MinIMU-9 http://www.pololu.com/catalog/product/1264. I want to use this in place of the ArduIMU since I already have it. I have an Arduino Pro mini withe Atmega328p (clone actually), and that would be the dedicated AHRS board. I either want to run ArduIMU software on the Pro mini and adjust the code to read the Pololu IMU, or use the code that already reads the Pololu IMU and trick the ArduPilot into thinking it is the ArduIMU. I have played with this a bit myself but I seem to be a bit stuck, as my programming skills are mediocre at best.
I think it would be better to run ArduIMU modified to read the Pololu IMU, as it would just interface with ArduPilot much better. For example, the GPS runs through the ArduIMU. The thing I seem to be lost on how to fix is that the Pololu IMU already does some of the processing (I believe), and it has two data out ports. Whereas the ArduIMU, if I understand correctly, has to actually monitor each sensor itself.
If anybody can think of a way for me to do this that would be great! Also I have an Arduino Mega that should be arriving any day, so if I would be better off running ArduPlane 2.0 and interfacing with the Mega, that would be even better as ArduPlane 2.0 would be much better anyway. I would create my own shield for the IMU and GPS so having 50 jumper wires would not have to happen.
Thanks!
Permalink Reply by Sean Thomas on January 30, 2012 at 3:00pm Oops I meant ArduPilot Mega 1.0 every time I said 2.0.
Permalink Reply by JesseJay on January 31, 2012 at 12:57am The MinIMU-9 just has i2c sensors like the ArduIMU. It does no on board processing. The ArduIMU V3 will off load some of the calculations to a DMP6000 once they workout the firmware licensing issue, and has the cpu built in. Also, the MinIMU-9 example code is based ArduIMU v1.5... so technically you are dealing with ArduIMU either way. Your way, using the MinIMU is just more work but I don't see why you could not get it working.
Permalink Reply by Sean Thomas on January 31, 2012 at 8:37pm I'm sure it's user error!
This is the code I have so far from essentially smashing the two codes together, but it still doesn't work. (Code compiles but I get incorrect sensor readings in the serial monitor).
Main Page
// Released under Creative Commons License
// Code by Jordi Munoz and William Premerlani, Supported by Chris Anderson (Wired) and Nathan Sindle (SparkFun).
// Version 1.0 for flat board updated by Doug Weibel and Jose Julio// Axis definition: X axis pointing forward, Y axis pointing to the right and Z axis pointing down.
// Positive pitch : nose up
// Positive roll : right wing down
// Positive yaw : clockwise#include <avr/eeprom.h>
#include <Wire.h>//**********************************************************************
// This section contains USER PARAMETERS !!!
//**********************************************************************// *** NOTE! Hardware version - Can be used for v1 (daughterboards) or v2 (flat)
#define BOARD_VERSION 2 // 1 For V1 and 2 for V2// Ublox gps is recommended!
#define GPS_PROTOCOL 2 // 1 - Ublox, 2 - EM406, 3 - NMEA We have only tested with Ublox// Enable Air Start uses Remove Before Fly flag - connection to pin 6 on ArduPilot
#define ENABLE_AIR_START 1 // 1 if using airstart/groundstart signaling, 0 if not
#define GROUNDSTART_PIN 8 // Pin number used for ground start signal (recommend 10 on v1 and 8 on v2 hardware)/*Min Speed Filter for Yaw drift Correction*/
#define SPEEDFILT 2 // >1 use min speed filter for yaw drift cancellation, 0=do not use speed filter/*For debugging propurses*/
#define PRINT_DEBUG 0 //Will print Debug messages//OUTPUTMODE=1 will print the corrected data, 0 will print uncorrected data of the gyros (with drift), 2 will print accelerometer only data
#define OUTPUTMODE 1#define PRINT_DCM 0 //Will print the whole direction cosine matrix
#define PRINT_ANALOGS 0 //Will print the analog raw data
#define PRINT_EULER 1 //Will print the Euler angles Roll, Pitch and Yaw
#define PRINT_GPS 1 //Will print GPS data// *** NOTE! To use AdruIMU with ArduPilot you must select binary output messages
#define PRINT_BINARY 0 //Will print binary message and suppress ASCII messages (above)// *** NOTE! Performance reporting is only supported for Ublox. Set to 0 for others
#define PERFORMANCE_REPORTING 1 //Will include performance reports in the binary output ~ 1/2 min/* Support for optional magnetometer (1 enabled, 0 dissabled) */
#define USE_MAGNETOMETER 1 // use 1 if you want to make yaw gyro drift corrections using the optional magnetometer
// End of user parameters
//**********************************************************************#define SOFTWARE_VER "1.6"
// ADC : Voltage reference 3.3v / 10bits(1024 steps) => 3.22mV/ADC step
// ADXL335 Sensitivity(from datasheet) => 330mV/g, 3.22mV/ADC step => 330/3.22 = 102.48
// Tested value : 101
#define GRAVITY 256 //this equivalent to 1G in the raw data coming from the accelerometer
#define Accel_Scale(x) x*(GRAVITY/9.81)//Scaling the raw data of the accel to actual acceleration in meters for seconds square#define ToRad(x) (x*0.01745329252) // *pi/180
#define ToDeg(x) (x*57.2957795131) // *180/pi// L3G4200D gyro: 2000 dps full scale
// 70 mdps/digit; 1 dps = 0.07
#define Gyro_Gain_X 0.07 //X axis Gyro gain
#define Gyro_Gain_Y 0.07 //Y axis Gyro gain
#define Gyro_Gain_Z 0.07 //Z axis Gyro gain
#define Gyro_Scaled_X(x) ((x)*ToRad(Gyro_Gain_X)) //Return the scaled ADC raw data of the gyro in radians for second
#define Gyro_Scaled_Y(x) ((x)*ToRad(Gyro_Gain_Y)) //Return the scaled ADC raw data of the gyro in radians for second
#define Gyro_Scaled_Z(x) ((x)*ToRad(Gyro_Gain_Z)) //Return the scaled ADC raw data of the gyro in radians for second// LSM303 magnetometer calibration constants; use the Calibrate example from
// the Pololu LSM303 library to find the right values for your board
#define M_X_MIN -796
#define M_Y_MIN -457
#define M_Z_MIN -424
#define M_X_MAX 197
#define M_Y_MAX 535
#define M_Z_MAX 397#define Kp_ROLLPITCH 0.02
#define Ki_ROLLPITCH 0.00002
#define Kp_YAW 1.2
#define Ki_YAW 0.00002#define OUTPUTMODE 1
/*UBLOX Maximum payload length*/
#define UBX_MAXPAYLOAD 56#define ADC_WARM_CYCLES 75
#define FALSE 0
#define TRUE 1
float G_Dt=0.02;
// Integration time (DCM algorithm)
long timeNow=0;
long timer=0; //general purpuse timer
long timer_old;
long timer24=0; //Second timer used to print values
int AN[6]; //array that stores the gyro and accelerometer data
int AN_OFFSET[6]={0,0,0,0,0,0}; //Array that stores the Offset of the sensorsboolean groundstartDone = false; // Used to not repeat ground start
int gyro_x;
int gyro_y;
int gyro_z;
int accel_x;
int accel_y;
int accel_z;
int magnetom_x;
int magnetom_y;
int magnetom_z;
float c_magnetom_x;
float c_magnetom_y;
float c_magnetom_z;
float MAG_Heading;float Accel_Vector[3]= {0,0,0}; //Store the acceleration in a vector
float Gyro_Vector[3]= {0,0,0};//Store the gyros turn rate in a vector
float Omega_Vector[3]= {0,0,0}; //Corrected Gyro_Vector data
float Omega_P[3]= {0,0,0};//Omega Proportional correction
float Omega_I[3]= {0,0,0};//Omega Integrator
float Omega[3]= {0,0,0};// Euler angles
float roll;
float pitch;
float yaw;float errorRollPitch[3]= {0,0,0};
float errorYaw[3]= {0,0,0};
float errorCourse=180;unsigned int counter=0;
byte gyro_sat=0;float DCM_Matrix[3][3]= {
1,0,0 }
0,1,0 }
0,0,1 }
float Update_Matrix[3][3]={{0,1,2},{3,4,5},{6,7,8}}; //Gyros here
float Temporary_Matrix[3][3]={
0,0,0 }
0,0,0 }
0,0,0 }
//GPS//GPS stuff
union long_union {
int32_t dword;
uint8_t byte[4];
} longUnion;union int_union {
int16_t word;
uint8_t byte[2];
} intUnion;/*Flight GPS variables*/
int gpsFix=1; //This variable store the status of the GPS
int gpsFixnew=0; //used to flag when new gps data received - used for binary output message flags
long lat=0; // store the Latitude from the gps to pass to output
long lon=0; // Store the Longitude from the gps to pass to output
long alt_MSL=0; //This is the altitude in millimeters
long iTOW=0; //GPS Millisecond Time of Week
long alt=0; //Height above Ellipsoid in millimeters
float speed_3d=0; //Speed (3-D)
float ground_speed=0;// This is the velocity your "plane" is traveling in meters for second, 1Meters/Second= 3.6Km/H = 1.944 knots
float ground_course=90;//This is the runaway direction of you "plane" in degrees
byte numSV=0; //Number of Sats used.
float ecefVZ=0; //Vertical Speed in m/s
unsigned long GPS_timer=0;#if GPS_PROTOCOL == 1
// GPS UBLOX
byte ck_a=0; // Packet checksum
byte ck_b=0;
byte UBX_step=0;
byte UBX_class=0;
byte UBX_id=0;
byte UBX_payload_length_hi=0;
byte UBX_payload_length_lo=0;
byte UBX_payload_counter=0;
byte UBX_buffer[UBX_MAXPAYLOAD];
byte UBX_ck_a=0;
byte UBX_ck_b=0;
#endif//ADC variables
volatile uint8_t MuxSel=0;
volatile uint8_t analog_reference = DEFAULT;
volatile uint16_t analog_buffer[8];
volatile uint8_t analog_count[8];
#if BOARD_VERSION == 1
uint8_t sensors[6] = {0,2,1,3,5,4}; // Use these two lines for Hardware v1 (w/ daughterboards)
int SENSOR_SIGN[]= {1,-1,1,-1,1,-1,-1,-1,-1}; //Sensor: GYROX, GYROY, GYROZ, ACCELX, ACCELY, ACCELZ
#endif
#if BOARD_VERSION == 2
uint8_t sensors[6] = {6,7,3,0,1,2}; // For Hardware v2 flat
int SENSOR_SIGN[] = {1,-1,-1,1,-1,1,-1,-1,-1};
#endif
// Performance Monitoring variables
// Data collected and reported for ~1/2 minute intervals
#if PERFORMANCE_REPORTING == 1
int mainLoop_count = 0; //Main loop cycles since last report
int G_Dt_max = 0.0; //Max main loop cycle time in milliseconds
byte gyro_sat_count = 0;
byte adc_constraints = 0;
byte renorm_sqrt_count = 0;
byte renorm_blowup_count = 0;
byte gps_payload_error_count = 0;
byte gps_checksum_error_count = 0;
byte gps_pos_fix_count = 0;
byte gps_nav_fix_count = 0;
byte gps_messages_sent = 0;
long perf_mon_timer = 0;
unsigned int imu_health = 65012;
#endif//*****************************************************************************************
void setup()
Serial.begin(38400);
pinMode(2,OUTPUT); //Serial Mux
digitalWrite(2,HIGH); //Serial Mux
pinMode(5,OUTPUT); //Red LED
pinMode(6,OUTPUT); // Blue LED
pinMode(7,OUTPUT); // Yellow LED
pinMode(GROUNDSTART_PIN,INPUT); // Remove Before Fly flag (pin 6 on ArduPilot)
digitalWrite(GROUNDSTART_PIN,HIGH);
Analog_Reference(EXTERNAL);//Using external analog reference
Analog_Init();
debug_print("Welcome...");
debug_print("You are using Hardware Version 1...");
#endif
debug_print("You are using Hardware Version 2...");
#endif
//Serial.print("ArduIMU: v");
//Serial.println(SOFTWARE_VER);
debug_handler(0);//Printing version
#if BOARD_VERSION != 1
#if USE_MAGNETOMETER==1
debug_handler(3);
I2C_Init();
delay(100);
// Magnetometer initialization
Compass_Init();
#endif
#endif
if(ENABLE_AIR_START){
debug_handler(1);
//Serial.println("***Air Start");
startup_air();
}else{
//Serial.println("***Ground Start");
debug_handler(2);
startup_ground();
delay(250);
Read_adc_raw(); // ADC initialization
timer=DIYmillis();
delay(20);
void loop() //Main Loop
if((millis()-timer)>=20) // Main loop runs at 50Hz
counter++;
timer_old = timer;
timer = timeNow;
mainLoop_count++;
if (timer-timer_old > G_Dt_max) G_Dt_max = timer-timer_old;
#endif
G_Dt = (timer-timer_old)/1000.0; // Real time of loop run. We use this on the DCM algorithm (gyro integration time)
if(G_Dt > 1)
G_Dt = 0; //keeps dt from blowing up, goes to zero to keep gyros from departing
// *** DCM algorithm
Read_adc_raw();
if (counter > 5) // Read compass data at 10Hz... (5 loop runs)
counter=0;
Read_Compass(); // Read I2C magnetometer
Compass_Heading(); // Calculate magnetic heading
#endif
#endif
Matrix_update();Normalize();
Drift_correction();
Euler_angles();
#if PRINT_BINARY == 1
printdata(); //Send info via serial
#endif
//Turn on the LED when you saturate any of the gyros.
if((abs(Gyro_Vector[0])>=ToRad(300))||(abs(Gyro_Vector[1])>=ToRad(300))||(abs(Gyro_Vector[2])>=ToRad(300)))
gyro_sat=1;
gyro_sat_count++;
#endif
digitalWrite(5,HIGH);
counter++;
if (counter >= 5){
counter = 0;
// Do these things every 5th time through the main cycle
// This section gets called every 1000/(20*5) = 10Hz
// doing it this way removes the need for another 'millis()' call
decode_gps();
//Here we will check if we are getting a signal to ground start
if(digitalRead(GROUNDSTART_PIN) == LOW && groundstartDone == false) startup_ground();
// Display Status on LEDs
// GYRO Saturation
if(gyro_sat>=1)
digitalWrite(5,HIGH); //Turn Red LED when gyro is saturated.
if(gyro_sat>=8) // keep the LED on for 8/10ths of a second
gyro_sat=0;
else
gyro_sat++;
else
digitalWrite(5,LOW);
// YAW correction
if(ground_speed<SPEEDFILT)
digitalWrite(7,HIGH); // Turn on yellow LED if speed too slow and yaw correction supressed
else
digitalWrite(7,LOW);
// GPS Fix
if(gpsFix==0) // yep its backwards 0 means a good fix in GPS world!
digitalWrite(6,HIGH); //Turn Blue LED when gps is fixed.
else
digitalWrite(6,LOW);
#if !PRINT_BINARY
#endif
if (timeNow-perf_mon_timer > 30000)
printPerfData(timeNow-perf_mon_timer);
perf_mon_timer=timeNow;
#endif}
void startup_ground(void)
uint16_t temp=0;
debug_handler(2);
for(int c=0; c<ADC_WARM_CYCLES; c++)
delay(50);
Read_adc_raw();
delay(50);
Read_adc_raw();
delay(20);
Read_adc_raw();
for(int y=0; y<=5; y++) // Read first initial ADC values for offset.
AN_OFFSET[y]=AN[y];
delay(20);
for(int i=0;i<400;i++) // We take some readings...
Read_adc_raw();
for(int y=0; y<=5; y++) // Read initial ADC values for offset (averaging).
AN_OFFSET[y]=AN_OFFSET[y]*0.8 + AN[y]*0.2;
delay(20);
AN_OFFSET[5]-=GRAVITY*SENSOR_SIGN[5];
Serial.println(AN_OFFSET[y]);
temp = ((AN_OFFSET[y]-200.f)*100.0f);
eeprom_busy_wait();
eeprom_write_word((uint16_t *) (y*2+2), temp);
groundstartDone = true;
Serial.println("***Ground Start complete");
void startup_air(void)
uint16_t temp=0;for(int y=0; y<=5; y++)
eeprom_busy_wait();
temp = eeprom_read_word((uint16_t *) (y*2+2));
AN_OFFSET[y] = temp/100.f+200.f;
Serial.println("***Air Start complete");
void debug_print(char string[])
#if PRINT_DEBUG != 0
Serial.print("???");
Serial.print(string);
Serial.println("***");
#endif
}void debug_handler(byte message)
static unsigned long BAD_Checksum=0;
switch(message)
case 0:
Serial.print("???Software Version ");
Serial.print(SOFTWARE_VER);
break;
case 1:
Serial.println("???Air Start!***");
break;
case 2:
Serial.println("???Ground Start!***");
break;
case 3:
Serial.println("???Enabling Magneto...***");
break;
case 10:
BAD_Checksum++;
Serial.print("???GPS Bad Checksum: ");
Serial.print(BAD_Checksum);
Serial.println("...***");
break;
default:
Serial.println("???Invalid debug ID...***");
break;
#endif
EEPROM memory map0 0x00 Unused
1 0x01 ..
2 0x02 AN_OFFSET[0]
3 0x03 ..
4 0x04 AN_OFFSET[1]
5 0x05 ..
6 0x06 AN_OFFSET[2]
7 0x07 ..
8 0x08 AN_OFFSET[3]
9 0x09 ..
10 0x0A AN_OFFSET[4]
11 0x0B ..
12 0x0C AN_OFFSET[5]
13 0x0D ..
14 0x0E Unused
15 0x0F ..
*/Compass Page
/* I2C HMC5843 magnetometer */
/* ******************************************************* */// Local magnetic declination
// I use this web : http://www.ngdc.noaa.gov/geomagmodels/Declination.jsp
#define MAGNETIC_DECLINATION -6.0 // not used now -> magnetic bearingint CompassAddress = 0x1E; //0x3C //0x3D; //(0x42>>1);
void I2C_Init()
Wire.begin();
void Compass_Init()
Wire.beginTransmission(CompassAddress);
Wire.send(0x02);
Wire.send(0x00); // Set continouos mode (default to 10Hz)
Wire.endTransmission(); //end transmission
}void Read_Compass()
int i = 0;
byte buff[6];
Wire.send(0x03); //sends address to read from
//Wire.beginTransmission(CompassAddress);
Wire.requestFrom(CompassAddress, 6); // request 6 bytes from device
while(Wire.available()) // ((Wire.available())&&(i<6))
buff[i] = Wire.receive(); // receive one byte
i++;
if (i==6) // All bytes received?
// MSB byte first, then LSB, X,Y,Z
magnetom_x = SENSOR_SIGN[6]*((((int)buff[2]) 8) | buff[3]); // X axis (internal sensor y axis)
magnetom_y = SENSOR_SIGN[7]*((((int)buff[0]) 8) | buff[1]); // Y axis (internal sensor x axis)
magnetom_z = SENSOR_SIGN[8]*((((int)buff[4]) 8) | buff[5]); // Z axis
else
Serial.println("!ERR: Mag data");
void Compass_Heading()
float MAG_X;
float MAG_Y;
float cos_roll;
float sin_roll;
float cos_pitch;
float sin_pitch;
cos_roll = cos(roll);
sin_roll = sin(roll);
cos_pitch = cos(pitch);
sin_pitch = sin(pitch);
// Tilt compensated Magnetic filed X:
MAG_X = magnetom_x*cos_pitch+magnetom_y*sin_roll*sin_pitch+magnetom_z*cos_roll*sin_pitch;
// Tilt compensated Magnetic filed Y:
MAG_Y = magnetom_y*cos_roll-magnetom_z*sin_roll;
// Magnetic Heading
MAG_Heading = atan2(-MAG_Y,MAG_X);
Permalink Reply by JesseJay on January 31, 2012 at 9:17pm Hmm. I'd start off by just using reading the raw values, do those look good? Then does the straight MinIMU code work? IF so, figure what parts your merged, and look for the problem... line by line till you find it.
Permalink Reply by Sean Thomas on January 31, 2012 at 11:39pm
!!!VER:1.6,AN0:168.00,AN1:-168.00,AN2:-168.00,AN3:168.00,AN4:-168.00,AN5:168.00,MGX:0,MGY:0,MGZ:0,MGH:0.00,TOW:0***
That's what I get over and over when I read raw values... must have been an error in my code transfer. I'll try and run back through it all tomorrow and see what I could come up with. Thanks for the help!
Sean
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
11 members
182 members
1290 members
684 members
Powered by
