I used and extended the ArduPilot code for an approach to a special FPV issue:
'Where should I put my FPV AV-TX antenna'
In down position video transmission is often better than in up position.
But hey, bad news, sometimes we have to land...
So I came to the solution of toppling the antenna.
The test flight video shows the Barometric Antenna Toppler - B.A.T. - in action.
The antenna is toppled down when the plane is above 25m and toppled up when it's below 20m.
(Values can be changed.)
The toppling is controlled by an ArduPlane software extension using the barometric sensor.
Toppling is also possible manually e.g. for ground testing.
This video shows the B.A.T. in my Rookie testship:
http://vimeo.com/teamredfox/bat
Next step is the integration in the left wing of my Knurrus Maximus FPV.
There the antenna will topple through the nose edge of the wing.
By the way, this is my first homebrewed CloverLeave antenna build with informations from IBCrazy and calculations from rcexplorer.se.
Bye
JR
Tags:
Permalink Reply by Ken on April 23, 2012 at 4:22pm Putting it upside down inside the fin would have been harder?
Permalink Reply by Jörg Rothfuchs on April 23, 2012 at 4:30pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
83 members
24 members
682 members
1288 members
Powered by
