Dears,
I'm back to the world of Arducopter since a few months of absence due to personal problems and I didn't keep up with all the things that happened.
Browsing around I saw that there are 4 firmware available:
I was wondering it they all run on the same HW (both electronics and frame) and what you would recommend using.
And also if there is comparison of the various features available in different versions
Tags:
ACM (Arducopter Mega) is not officially released yet, so be careful, it has the most features
Ardupirates is current released code, this is the one recommended
Multipilot runs on different hardware (Ardupilot32), it uses a 72MHz ARM processor
Permalink Reply by Russell B. Sutton on April 12, 2011 at 11:05pm I have started to build a quadcopter and have decided to use the ardupilot mega w/ sensor shield. I have already recieved the ardupilot from DIY-Drones it is very easy to use. I believe aero, quadcopter, and adurPirates all come from the same back ground. I will be experimenting with the Ardupirates code first. Arduino platform has the most potential for the development and implementation of technology in the drone world so far.
Permalink Reply by Simone Chiaretta on May 4, 2011 at 7:24am as you may guess for the delay in the response, I've been brought away again :)
But thank you for the answers.
I'll start with the normal arducopter to see if everything works, and then will switch to ArduPirates.
But I have the impression that by the time I finish building the quad, the ACM will be ready :D
Permalink Reply by patrice.rance on May 4, 2011 at 7:50am
Permalink Reply by Simone Chiaretta on May 4, 2011 at 7:53am Nice landing gears :)
Not sure my wife will like me flying the quad inside the kitchen :)
Permalink Reply by Daniel Gru on May 4, 2011 at 8:12am
Permalink Reply by Simone Chiaretta on May 4, 2011 at 8:13am
Permalink Reply by Forbzy on May 5, 2011 at 2:59pm
Permalink Reply by chris g on May 5, 2011 at 10:28pm
Permalink Reply by Forbzy on May 6, 2011 at 6:19am
Permalink Reply by estebanflyer on June 3, 2011 at 11:04pm I need to know if there is a difference between the Ardupilot Mega and the Arducopter. I received an ArduPilot Mega with GPS, xbee, and magnetometer. While ordering, I could choose in between the code for a quad or for a fixed wing. I chose quad, since that is what I have flying and working right now (with a GU 344 triaxial gyro)
If I follow the instructions of assembly of the Arducopter instead of the ArduPilot Mega, will it work the same? If I download all the software for the Arducopter and start building it and setting up the configuration; will I burn anything?
Thank you very much!!! This community is so overwhelming, No matter how much I read and browse, there is always something new and amazing.
Permalink Reply by Russell B. Sutton on June 3, 2011 at 11:15pm Ardupilot mega is the flight computer, The IMU is the sensor computer, Arducopter is the name of the code. AC2 is the latest beta Arducopter code. Arducopter 1 is the first code. ArduPiratesNG is the better working 1st version of Adrucopter 1 code.
1295 members
688 members
185 members
51 members
Powered by
