hi,
nothing much is showing on the apm when i play a log file.
This is a video exampel of a flight i did yesterday, gps light was solid blue, so it mean at least 5 sat (only 2 notified in the video) and instruments not moving much.
did i missed something?
here is the video
Also how and where do you set the clock for have right time stamped log files?
thx for your help
Tags: files, log
you never get gps lock.
check the cables between your apm and gps
also check your gps firmware version
hi,
thx for the tip, but i guess the gps is ok, cause when i connect the apm to the quad, and i get blue light, it show my position on the map, and when i fly and i use the rtl function it works, example:
Could that be working even i had bad conenctions or wrong firmware?
thx for your help
best regards
what version firmware are you using on your apm?
i run the latest 2.5.3, something quite funny i ve noticed, even my position is shown, if i run test/ gps, nothing is shown, wich is not the case for test/ altitude
here is the log file of the flight of the video
http://www.4shared.com/zip/WaeY4q95/fwdlogs.html
hope it ll help
thx for your help michael
btw, is it possible to set the time somewhere?
i ve just recorded a new video for you for show you what i ve wrote above.
thx for your help
something i just noticed, i ve just played the logfiles generated when i ve record the screen videos for you, and they play just fine. Only log files generated when flying have an issue
hope it ll help
best regards
hi,
any news?
the whole issue if if the apm has detected the gps or not. note the blue led on the apm, not the gps.
hi michael,
if the apm didn t detect the gps, could a rtl mode works?
hi michael,
could that issue be linked or related to the gps issue?
http://www.diydrones.com/forum/topics/loiter-mode-holding-nothing-a...
also, i ve installed the optical flow, that works like a charm on the cli.
the thing is, i ve put it on the side of the quadcopter, so i was wondering if there is a way , an orientation to install it, or could it be installed in any position (as long as the lense shoot the ground) ?
in what mode exactly is it used? alt mode? loiter mode or all mode?
thx to reply, i am getting despaired with this issue.
best regards
herve
