Please help me out this issue. I need the guide lines for designing a VTOL aircraft.
Tags:
Permalink Reply by anvith on March 15, 2012 at 8:50pm Macboffin thanks a lot but initially when we have capability of designing of our own then why do we need buy a stuff. See for example in J.D.Andruson's "Aircraft performance and design" he clearly explains about the normal aircraft like Cessna aircraft. So in case of VTOL it's a head breaking task. Thereby, do you have any proper guide line for designing a VTOL aircraft.
Permalink Reply by Bim on March 15, 2012 at 2:44pm Maybe you could get a few ideas from this UAV(Panther by IAI).
Permalink Reply by anvith on March 15, 2012 at 8:51pm Thanks Bim, but do you know the tit-rotor concept, at what gear ratio do it turn.
Permalink Reply by Greg Fletcher on March 15, 2012 at 9:43pm A lite efficient airframe and tricopter motor arraignment. Two front motors tilt 90 deg for forward or 0 for hover flight. Tail motor is shut down for forward fixed wing mode. Need to control attitude during transition from hover to forward flight. I have thought a lot about this, done some sketches and calculations. Plane/Copter or Copter/Plane depending on if you are taking of or landing.
Permalink Reply by Brad Hughey on March 17, 2012 at 9:41am Greg, transitional flight modes are the achilles heel of every VTOL aircraft, even conventional helicopters. This is where the Osprey is most vulnerable to be sure, with the added loss of pitch control as the nacelles are moving.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
48 members
111 members
137 members
693 members
Powered by
