here is a thrust calculator you will need prop size prop pitch and kv of the motor and then you will have to google your elevation air density. and with the kv you will have to multiply the kv by voltage.
I am currently using 1400kv motor's with 7.4v battery and 10x4.5 props for heavy lifting
