sometimes when i get to a way point the airplane thinks it missed it and turns around and tries again to hit the same way point if im flying a grid pattern it messes up my grid because instead of going to the next waypoint it tries to hit the same one again do i need to adjust the way point radius ??? or is there something else to adjust ??
I'm only flying around 100-200 feet altitude. What should my waypoint and and RTL radius be? The default 30 meters sounds way too much for that altitude.
I had same problem before and found out that I had changed the way point radius down to 10, changed it back to default (30) and is lot better now. I have a question, let say I have a mission uploaded and am flying manual, if I switch to Auto where the plane start? he goes look for way point 1 or start on the nearest point?
question 2- after the plane complete the mission and I switched back to manual ...if I switch back to auto will it fly the mission again ?
