What is the voltage tolerance on APM usually speed controller BEC gives 5.5 volt which AMP dose not like and behave erratic.
Tags:
Permalink Reply by Colin Bouriquet on January 8, 2012 at 1:20pm I would be interested by an answer to this question too... The ESC used in the Easystar II RR ( MULTIcont BL-20 SD ) has a BEC that delivers 5.5V is it OK to plug it into the APM2 output rail ? Thanks.
Permalink Reply by tuckerobie on January 8, 2012 at 9:20pm I was told 5v
Permalink Reply by James masterman on January 8, 2012 at 10:16pm I'm surprised it is not more clearly spelled out in the manual, but it seems that 5v +/- a small amount (like 0.2v) is what is required for APM 1. I assume APM 2 is similar. This is based on searching through old posts.
I am using a separate UBEC that outputs 5v,which has never cause a problem. It is just a shame that a lot of ESC's output 5.5v, which causes APM to do strange things.Otherwise I could have a neater setup inside my plane.
I would avoid plugging your 5.5v BEC into the APM 2 rail. You can buy a UBEC for <$15 that will output the correct voltage and be safer.
Permalink Reply by Colin Bouriquet on January 9, 2012 at 1:41pm Thanks for the answers guys!
I made a switchng regulator using LM2576-5 it gives perfect 5v output now APM is working ok you can find data sheet at;
http://www.ti.com/lit/ds/symlink/lm2576.pdf
it is 3A 5volt switching regulator with wide input range. i have isolated APM and servo voltages also.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
720 members
1355 members
207 members
Powered by
