What value in LOW_VOLT?
What value should I use for LOW_VOLT parameter for a 3S battery?
The default value it's 9.6, but that seems way too low.
Every time I try to search "lipo low voltage" I find hundreds of contradictory articles. What do you guys use?
Thanks!
  • Set it to 3.5v per cell (10.5v total), as per Randy's suggestion.
    Mine is hardwired to go off at 3.4, but I've had a (expensive!) voltage-drop Loss of Control event because of it. I'm happy to trade 3-4 minutes of flight time and range anxiety for less stressful landings.
    A new customisable alarm is onroute.
  • My understanding is that you can damage the lipo cell if it drops below 3 volts. My alarm goes off at around 3.5 volts so I think if you stay between 3.2 - 3.5 you should be fine.
    Randy
