Arducopter was flying fine for about 10 flights over the last 4 days. Today, hovering about 4 ft off the ground the heli did a flip (for no reason, it was in stable mode) and landed upside down. After repowering, 2 ESCs were sounding error codes (rapid beep), so I thought maybe I blew some ESCs or motors.
After rebooting, though, I could give rudder input and 2 motors would spin even though the Green LED was solid (indicating the "unarmed, safe to move" condition). Stranger still, I repower the board an hour later, and the heli initializes and I am able to arm it and the ESCs all work again. I even test hover over some grass. I land a bit hard and then the problem reappears.
Now at home, however, I cannot re-arm the board. Configurator does not show any Tx inputs. I know the Rx is good, since I switched it out with another known good one and double confirmed using a standard servo. My sensors all respond in Configurator. The board boots normally (flashing R G B, then solid Green).
I just do not know which board is damaged? I'm assuming it's the lower Mega board (since it's the one with the servo headers, plus it's cheaper), but want a more informed diagnosis.
Was fun while it lasted :^(
Tags: board, damaged, re-arm
check all your connectors, check if all pins are correctly soldered on both (the red and the blue) board
check your motor connections, check ESC power connections
i don't think that one of your main boards is damaged
I checked the pin connections as best I could and they seemed to be ok. I noticed that there is a blue led on the mega board (red board) that indicates the link status to the Rx. At boot, sometimes it will light up (good) and sometimes it stays off, so I think it has something to do with the trace that leads to the Rx input.
If you have those bullet connectors between ESCs and motors, make sure to check they all have good contact.
In my case I found several of them were rotating freely also when mated, causing bad electrical contact. I soldered them up solid.
Swapped in a new APM today and the quad is back in the air. :^)
Looks like my other APM was indeed damaged or had some defect so it is off to diydrones for repair (kudos to them for customer support!)
