which osd to use
hi , im after a osd to go with my amp but theres 2 in the store, wondering which is the better 1 to use , im after 1 that is easy to set up , any ideas?
cheers glen
  • MinimOSD is a DIY Drones thing and is new, and as such does not have a lot of documentation and tooling. This will likely grow however, as with most stuff here. It is meant to 'sense' everything through MAVlink, so has no sensors of it's own.
    Rembizi has been around for a while longer, was originally created and shared on RCGroups. I'm not sure about the status of the code (open source or not). It connects directly to sensors etc, however I have seen now and then projects to interface it to AruduPilot over the years. As a more mature project, it has a better setup support, if that's what you care about.
  • I hvae been wondering the same thing.. !!
    Eddie...
