Tags:
Permalink Reply by Erik Hatch on March 27, 2011 at 7:43am chris
what is mavlink hil version? i uploaded just the standard 2.011.....
erik
Permalink Reply by Jimmy P. on March 26, 2011 at 11:21am
Permalink Reply by Erik Hatch on March 26, 2011 at 11:30am jimmy
i think these are 2 separate issues.
1- the stabilize mode malfunction. i got this working correctly after i commented out the battery monitor function, reset via cli.
2- the altitude issue im not able resolve
are you using votlage monitor? i have not installed anything but apm 1.02
Permalink Reply by Jimmy P. on March 26, 2011 at 1:10pm
Permalink Reply by Erik Hatch on March 26, 2011 at 1:28pm
Permalink Reply by palo sestak on March 28, 2011 at 12:30am Guys,
on Saturday i flew at last with success. Stabilization and RTL worked perfect even in really strong wind.
Here is my setup:
aircraft is high-wing, 2m wings span, very stable one.
APM of version 1.02, MTK16, no changes in APM code, except GPS configuration in APM_config.h, no additional sensors, just APM + OILPAN 2.0 + MTK16.
I had no waypoints set yet, just wanted to test stabilization and RTL. Anyway Saturday event wasn't without problems. First flight was terrible - i even didn't try to switch on RTL because stabilization didn't work. After switching on the stabi, airframe started make big waves. It was high enough so i just only guess the elevator went to its max (pulled). After i landed switch off/on, got locked home and flew again, stabilization worked perfect. I had not yet stabilization system installed on my models, but this works great - no wavering just straight flight.
I flew farther from me (500 meters) then i switched to RTL and aircrat returned to me ;o). I repeated this maneuver 3 times (against the wind, down the wind) and it worked still perfect.
But i had problems with log - the log is enabled but after my flights in the CLI i got unpleasant message from APM - no logs available, even if i the logs enabled (all). I erased and enabled logs bot nothing is recorded. Have somebody hint on it?
Next weekend - i try auto mode and if there will be more free time, i try to load APM 2.011 (or latest one, if there will be more recent).
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.5 members
1356 members
54 members
203 members
88 members
Powered by
