hello to all im interested in accquiring a hexacopter or octocopter to make aerial photography in a short areas of field.
im searching a solution RTF , that can carry a dslr camera (1.5 kg max) , an autonomy of 12 minuts and max altitude of 200 m ( this is not really important at all) . i've been searching on the web , and i want a cheap solution . about 2500 usd max .
i found this but i dont know if its able to move a dslr
3DR hexacopter C , with some extras , total cost 1700 usd aprox , i know that needs a mount and a stabilizer for the camera.
you know some model that can be usefull for that purpose or similar? thanks in advance!
Tags:
Permalink Reply by Andrew Chapman on February 3, 2013 at 9:52pm The Steadidrone H6X would be perfect for mid-weight DSLR use, high end build, comes in a kit form that just about fits your budget:
Permalink Reply by Luke Olson on February 5, 2013 at 12:53pm The H6X is more than $6,000 RTF. The 3DR hexacopter is probably the best option that's RTF if sticking to the $2,500 budget. Depending on the camera it might be too heavy for the 3DR hexacopter. A point and shoot camera would be no problem (even for the 3DR quadcopter).
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
1290 members
51 members
11 members
182 members
Powered by
