Would Mission planner run on Android tablet?
I was just thinking whether our mission planner would run on a Android tablet pc, it is windows based has usb input.  It would make it so much easier than carrying the whole laptop around.
http://www.ebay.com.au/itm/NEW-10-2-ANDROID-2-2-FLYTOUCH-III-TABLET-PC-WIFI-GPS-/320731928878?pt=AU_Tablets&hash=item4aad1cd92e
Can someone try it, please.
Regards Pete
  • In principle, if you root the android tablet, and install Linux. Then you would be able to install Mono, to support .Net apps _If_ that works, then you would be able to install Mission Planner.
    There are several free apps on Googleplay that help you install various flavours of Linux alongside Adroid - sharing the Ardroid-Arm Linux Kernel. You would need at least a dual core phone/tablet.
    Alternatively there is a proprietary version of Mono for Android.
    The mission planner will not run on that device. If you are interested in an android based solution check this out: http://diydrones.com/profiles/blogs/coptergcs-android-ground
