For teams relying on a professional survey drone or inspection drones, high-accuracy positioning has become essential. Surveying, infrastructure inspection, mapping, and precision cleaning all demand reliable centimeter-level data. The EFT X950 industrial-grade drone platform addresses this need with a design that makes RTK module installation straightforward and reliable. Equipped with an SMA-to-MMCX adapter cable, the platform streamlines antenna routing and module integration, allowing operators to equip their aircraft for high-precision missions with minimal effort.
http://www.youtube.com/shorts/NTwKD696wOM
Why RTK Matters on an Industrial Platform
RTK (Real-Time Kinematic) technology corrects standard GNSS signals to deliver far higher positional accuracy. For teams conducting topographic surveys, power-line inspections, building façade assessments, or large-area mapping, this precision reduces the need for extensive ground control points and improves the quality of deliverables. The challenge has often been integrating RTK modules cleanly into the airframe without compromising signal integrity, waterproofing, or ease of maintenance. The X950 was engineered with these practical requirements in mind.
The platform features a spacious flight-control bay, accessible mounting plate, and thoughtfully routed cable paths from the arms into the fuselage. These details turn what can be a fiddly upgrade into a repeatable, professional-grade procedure.
A Clear, Step-by-Step Installation Process
The official installation guide demonstrates how straightforward the process is. First, confirm that the primary flight-control modules are fully installed. Open the flight-controller mounting plate to gain access to the bay. Route the RTK antenna cable from the arm into the fuselage through the prepared channels. This routing keeps cables protected and maintains a clean internal layout.
Next, install the RTK antenna itself on the designated arm mount. The antenna base and protective cover secure firmly, ensuring a stable connection even during extended flights. Then install the RTK module inside the flight-control bay. Here the included SMA-to-MMCX adapter cable proves especially useful. If the chosen RTK module uses an SMA port, simply connect it through the adapter. If the module uses an MMCX port, connect it directly to the original cable without the adapter. Finally, link the RTK module to the flight controller and restore the mounting plate.
The entire sequence is designed for clarity and repeatability. Operators do not need to invent custom routing solutions or risk damaging cables during installation. The adapter cable removes compatibility friction between different RTK modules, giving teams flexibility in their choice of positioning hardware.
Built for Real Industrial Demands
The X950 is a lightweight yet capable industrial drone platform with a 950 mm wheelbase, compatibility with 23-inch propellers, IP54 protection, and a maximum takeoff weight of 10 kg. Its foldable arms and quick-detach landing gear support rapid transport between sites, while multiple payload mounting zones accommodate cameras, LiDAR, spotlights, or specialized tools alongside the RTK system. The large battery compartment and multi-duct cooling further support the longer flight times often required for precise data collection.
These attributes make the platform well suited for surveying missions, power-line and infrastructure work, precision mapping projects, and specialized cleaning or surveillance applications that benefit from accurate georeferencing. By simplifying RTK integration, the X950 lowers the barrier to high-accuracy operations without sacrificing the durability and expandability expected in professional environments.
Practical Advantages for Field Teams
Easy antenna routing and module installation translate directly into reduced setup time and fewer opportunities for error. Clean cable management improves long-term reliability and simplifies future maintenance or module swaps. Support for both SMA and MMCX connections means operators can select the RTK solution that best matches their workflow and budget. Combined with the platform’s open architecture, this flexibility helps teams standardize on a single airframe while adapting the avionics to specific project requirements.
In daily use, the result is higher productivity and greater confidence in the data collected. Whether mapping a construction site, inspecting elevated structures, or gathering geospatial intelligence, the X950 with properly installed RTK delivers the positioning performance modern industrial workflows demand.
A Platform Designed for Precision Professionals
The X950 industrial drone platform demonstrates that high-accuracy capability does not have to come with complicated installation or restrictive hardware choices. The inclusion of the SMA-to-MMCX adapter cable, combined with deliberate cable routing and an accessible flight-control bay, makes RTK integration both practical and professional. For operators focused on surveying, inspection, mapping, or any mission where precise positioning improves outcomes, the X950 offers a clear path to reliable RTK performance.
Equipped for easier antenna routing and module installation, this survey drone and industrial inspection drones platform helps teams move from ready-to-fly to ready-for-precision with confidence and efficiency.
As a professional drone manufacturer with years of focused R&D and production experience, EFT specializes in agricultural drones, industrial drone platforms, and educational/training drones. From intelligent spraying solutions and lightweight industrial platforms like the X950 to complete training equipment, we provide reliable, customizable products trusted by customers worldwide.
We warmly welcome inquiries about our agricultural, industrial, and educational drone solutions. Contact us today to discuss your specific requirements and discover how EFT can support your next project.
