Hi all
A friend of mine, an electrical engineer, referred me to this product:
http://www.digi.com/products/wireless-wired-embedded-solutions/zigb...
It's a XBee Pro on 868mhz, with a high power output capable of reaching 80km LoS.
Are these modules interchangeable, should I be able to follow the same configuration procedure as with the classing Xbee Pro 900mhz?
Who needs 3G :)
No problem, thanks for taking the time to induldge me, good night !
Accoriding to your link http://fpv-community.com/forum/showthread.php?tid=952, no-one in UK or Germany may use an XBee. :o
xbee pro 900, yes, I think it is not permitted; I think most EU residents use 2.4Ghz models
Only about 20mW is allowed in UK and Germany etc, wheras the 2.4ghz XBee is 50mW, so they're out on both counts!
I do already have Xbee868 connected to APM 1.0 via xtreembee on the test bench. It is compatibile in case of pinout, and software. However it needs external power source ,(XBee868 needs up to 800mA on full 300mW Tx power) xtreembee onboard voltage regulator is insufficient. Now I'm trying to overcome duty cycle.
Does anybody have working code with reset procedure implemented? Please share or PM me
Best Regards,
Wojtek
Why don't you use a dedicated 5 AMP UBEC?
It needs 3.3V, typical RC 5V UBEC  would fry it!
Now I don't use external power at all because on lowest tx power  Xtreembee voltage regulator is ok.
Even with this tx power set its really powerful - xbees must be separated by 7m or more to communicate (when closer received signal is too powerful) . Link on 5mW works flawless throught 3 to 4 solid brick walls (around 95% packets received).
There are many 3.3V UBECs to choose from, I'm sure there'll be one with 5AMP, otherwise 3A should be fine, too, http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
For people saying it's illegal...
Can you honestly say that you care? i wouldn't give a shit.
Cops have got no idea, and i doubt the FCC is driving around sporting ovals and paddocks looking for people over the power limit.
