Permalink Reply by Darren on March 21, 2011 at 7:24pm Robb, your going to need a custom APM_Config.h with the following
#define SERIAL3_BAUD 9600
If you need help setting this up, i can walk you through it...
Hit me up on PM or on Live Chat
Permalink Reply by sedat öztürk on September 19, 2011 at 12:58am Hello my friends,
I buy a set of ardupilotmega and a telemetry kit in order to use in my model plane.
But unfortunately I was unable to get a data link with my Xbee-XSC’s.As I search on google I read your comments about the subject. I have a XtreamBee V1.2 adapter on plane side and Sparkfun’s XBee Explorer USB on laptop side. Even if I set the baud to 9600 on config.h I barely can connect to the Ardupilotmega board. As I focused on the subject, I see that I am able to connect and get the data only twice with a success right after a firmware re-loading.If I power-off and on more than two times it is not possible to get any data. When I dig deeper on it I see that, after I reset the EEProm I also get the data only twice with a success.The worse thing is after the second power off, if I try to conect by the telemetry, I see that the EEProm changes. So if I reset the EEProm the link comes back… Do you have any idea?
Permalink Reply by Robb Smith on March 22, 2011 at 10:47am
Permalink Reply by Robb Smith on March 22, 2011 at 10:55am
Permalink Reply by Darren on March 22, 2011 at 11:51am Robb, on main page for diydrones, scroll to very bottom, you will find the DIY Drones Chat.
Permalink Reply by dylan on December 10, 2011 at 6:07pm Can you guys share what you did to get the SERIAL3_BAUD line changed and uploaded?
If you're using Planner, you don't need to change any code for that. Look for SERIAL3_BAUD in the parameters list and change the value to either 9, 19, 56, etc..
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
51 members
249 members
24 members
12 members
Powered by
