XP : MP fail to run after upgrade to 1.3.37
Hi All,
MP on Win XP refers -
I have installed MP 1.3.30 on an XP machine, running ok
 Upgraded MP to 1.3.37 successfully.
However, now running MP fails with msg ...not a valid win32 application. (see attached pic)
  Is there an installation pack for 1.3.37 for XP, which will run on XP?
    I intend to use this pc as my portable GCS
On the other hand -
I am also using MP 1.3.37 successfully on a Win 7 notebook, no problem.
 I am using this notebook as my default platform stationary GCS.
Yet installing MP 1.3.37 on a different Win 7 Notebook,
  it appears the 3DR Radio driver didn't install properly, can't connect with the radio module to the UAV,
yet with the usb cable, it connects.
So in summary -
1) Is there installable version of MP 1.3.37 which will run on XP
2) Which drivers are required for 3DR Radio on a Win7 Notebook,
     if the default driver from MP does not appear to work.
Thank you very much for any suggestions or pointers in the right direction.
Gerhard
  • They stopped supporting MP on win 98 it wont run the new versions you need to go back to an older version
    • Hi George,
      Thanks for your reply.
       I did resolve the issues -
      >> XP is no longer support in 1.3.37
      >> with the 3DR radio
        - Wrong driver,
                  downloaded the correct driver from the Silicon Labs website.
      Gerhard
