I have updated AMP to 1.55, XPlane to 9.70, and am using APM2.2 HIL, everything connects up and reading are all correct, but as soon as I enable auto/ stabilize mode the aircraft spirals down to the ground and creshed when on xplane?
Anyone got any ideas whats wrong?
My board is setup to run on my skyfun, and on xplane i am using a standard aircraft on xplane
Thanks for any help :)
What version of Xplane are you using?
I am using the latest XPlane version as I updated it a few days ago to see if it would solve the problem.  I think it is v9.70
Alex, Check your channels i think they are reversed. I was having the same problem but have fixed it by getting the DIP switches and radio channels in normal mode..
Thanks for advice, but thats not the problem, i figured out that you need to connect your rreciever up properly and then everything works fine in HIL, if you do not connect your reciever and radio to APM then it will not send out any commands to xplane, atleast thats what i have experienced
