Permalink Reply by Paul Hoi on June 12, 2012 at 11:17am Hey Morli,
I'm using the Xtend modules with the APM2 as well. I haven't gotten it working yet (waiting for a "test" module to come in that I'll connect to the APM2), though. I set the Baud rate for both the RF and TX transmitting to 9600 and the TX power level to 10 mW. The APM2 has a 5V pin and the board voltage (as X-CTU tells me) is 4.95V. Do I still need a logic level converter? Or can I connect the wires as follows:
APM2 XTEND MODULE
RX ----------------------------------------DI (pin 5 on the picture)
TX ----------------------------------------DO (pin 6)
+5V -------------------------------------VCC (pin 2)
GND ------------------------------------GND (pin 1)
I do not have the APM2-side Xtend hooked up to a developer board (I have a RS232 to TTL converter, though), as it didn't seem that that was necessary. Anyways, will the above configuration (with no logic level converter) work? Or do I need the converter?
Permalink Reply by steven jones on June 12, 2012 at 3:52pm I have had successes with the Xtend Module using the logic converter from the Xbee pro interface PCB on my APM1.
as above reducing the Transmit power of the module is a must for initial bench test as i had issues with the APM directly powering the module.
Permalink Reply by Paul Hoi on June 20, 2012 at 7:17am Hey Steven, how did you configure the Mission Planner GCS to interface with the Xtend? Still confused as to how everything needs to be configured on the GCS side.
Permalink Reply by Paul Hoi on June 22, 2012 at 11:22am If you're still interested, Colin, (or anyone else following this discussion), I'd refer you to my discussion -> http://diydrones.com/forum/topics/xtend-apm2-gcs-solution-and-more-...
I found a few solutions that work well.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.106 members
1279 members
671 members
183 members
182 members
Powered by
