Good news!
The beauty of this community is on the collaboration. This new firmware proves it.
I have the pleasure of announcing that "ArduCAM OSD" and "MinimOSD-Extra" teams are now working together to make MinimOSD better and better.
I've been planning this fusion with Gábor Zóltan and Pedro Santos and we've started a nice friendship.
We spend the latest days merging and retouching everything to improve your experience with the new firmware. The Wiki was also updated for matching the new resources.
What's up?
You'll se all those awesome improvements from MinimOSD-Extra as well as improvements we made together.
The latest one is the new auto detection and updating of the EEPROM mapping .
From now on both OSD Firmware and ArduCAM OSD Config Tool will share the same internal signature.
So, both will detect the need for an EEPROM remapping preventing from loading or saving truncated data.
After a firmware upgrading the OSD Config Tool will detect an outdated mapping updating it automatically.
If you update your firmware by other way, the new firmware will alert you on screen and the Config Tool will repair automatically before you load anything from the EEPROM.
Update your MinimOSD right now. The most important: Have fun!
Important NOTES:
  • After install the new "ArduCAM OSD Config Tool" remember that you need to update the Character Set. A new one is available on the install folder. From now on it will be always there as "OSD_Charset.mcm".
  • Both sides of the MinimOSD need to be powered during a Character Set updating. Max7456's internal memory is really picky about voltage level during a charset update.
Download it from here:
http://code.google.com/p/arducam-osd/downloads/list
Comment by mack goodman on November 20, 2012 at 10:41am
@Sandro, another question about powering my minimosd.
with the solder jumpers in place tying the two sides together , can I just use the rx from the APM and power the osd from a BEC that also powers my camera and my vtx?  In other words I would not be getting any power from the APM, only the signal.  If so would I still need to run a ground from the APM, so it would be ground and signal..
thanks
Comment by Medeiros on November 29, 2012 at 7:00pm
I'm using this camera: http://www.rangevideo.com/index.php?main_page=product_info&prod... (NTSC) and it's ok with the minimOSD. But I tested this one: http://hobbywireless.com/index.php?main_page=product_info&cPath... (PAL) and the text does't show on. Only show the image of camera without the information of minimOSD. What happen? I already save on PAL video mode but nothing...
Comment by Jumpy07 on December 8, 2012 at 3:52pm
Is PWM Rssi (Frsky) still supported by MinimOSD in the new version of MinimOSD Extra ?.. ie: the original mod which inolved soldering onto the MinimOSD ?
Many Thanks
Comment by gustavo on December 9, 2012 at 5:04am
i have updated the firmware ,  and it appears the "eeprom mapping outdated" message on screen update with osd tool
i assume it refers to char set, when updating char set it says, " error entering font mode , no data"
Any ideas what could be wrong ?
tnaks
Comment by Francis Ignacio on January 17, 2013 at 12:32pm
Can a two-way switch be used to change the screens from 1 to 2  in MinimOSD?
I don't really want to use the 3-way switch (aka flight mode switch)  to change screens from panel 1 to panel 2. If changing screens cannot be accomplished with a 2-way switch, then I won't have a choice but to use the mode switch.
Comment by Oliver Sumpton on January 17, 2013 at 12:35pm
Yep. Check "3 Switching by a momentary switch" on this page ->>
http://code.google.com/p/arducam-osd/wiki/Cfg_Screen_Change
Comment by Lherning on January 22, 2013 at 4:36pm
How can I update with out the FTDI cable? please help.
Comment by Oliver Sumpton on January 22, 2013 at 10:39pm
Comment by Lherning on January 23, 2013 at 6:59am
Thanks!
Comment by Francis Ignacio on January 23, 2013 at 2:39pm
MinimOSD Subject Matter Experts;
I had recently purchased the MinimOSD from DIYDrone store.
I configured the MinimOSD to my desired layout of panels 1 and 2, and had data displayed on the video screen. However, the overlay data is not showing completely. Some of the characters do not show up or appear faded.
In the process of troubleshooting to make it work, the heads up display all of the sudden no longer shows up, the boot up sequence does not even appear at initial power up.
I have re-flashed and reconfigured the MinimOSD per the wiki instructions (http://code.google.com/p/arducam-osd/ ) about 10 times, but with the same results.
I also have contacted 3DR help support.  It took them several days to email back just to say that I needed to follow the instructions (http://code.google.com/p/arducam-osd/), which what I have been doing all along since I got the OSD.
I hope someone can help me figure out what's going with the MinimOSD. I might have gotten a dud.
I appreciate any help.
Thank you!
Comment
