Dynam Hawk Sky Brushless/Li-Poly/4ch RTF $119.00 EasyStar clone.
After looking at the suggested planes for use as a UAV, I noticed there not all that cheap.
The plane considered for a UAV builder "on a budget" was still something like $110.00 without any electronics!
I know the Easy Star is a pretty popular model in use with UAV construction, and even that is bumping $200.00 without a brushless motor.
I came across the Dynam Hawk Sky and saw for $119.00 you get a plane simular to the body style of the easy star, a brushless and li-poly battery upgrade, and everything needed to fly out of the box.
so my question pretty much is,
first of all, does anyone own this plane?
what is your guy's opinions on this plane?
do you think it will get the job done?
-Mike
Comment by Chris Anderson on October 4, 2009 at 12:53pm
I think that one's new. Looks like a good deal--just wish they'd offer it without that rubbish RC gear. Still cheap enough to get and just throw the RC gear away.
Comment by Caleb M on October 4, 2009 at 2:31pm
I added ailerons on my wildhawk (easystar clone) long ago. i think doing so to an easystar would be a great idea.
Admin
Comment by Thomas J Coyle III on October 4, 2009 at 3:10pm
Michael,
The ailerons are nice. Wish that they came standard on the EZ*. It would make it much easier to fly than with just the rudder. However....
If you read the Nitro Planes fine print closely, it says that the R/C equipment is 35MHz which is only used in Europe. Unless the 35MHz is a misprint, you will not be able to legally use the R/C equipment in the US.
Just a thought.
TCIII
Comment by Chris Anderson on October 4, 2009 at 3:59pm
Thomas,
I presume they replace it with 72Mhz gear for the US. Still rubbish, though, and no toggle or 5th channel so you'll have to replace it for UAV use.
Comment by Paul Bealing on October 4, 2009 at 4:42pm
Hello
I've been flying the same Dynam HawkSky for over a year (setup for fpv) and have two more work in progress. The main one will have all the UAV gear, including Ardupilot. I've recently put some info up on my RC Groups blog.
http://www.rcgroups.com/forums/member.php?u=276302
I'm building a custom circuit board for the electronics. The plan is to simplify construction and wiring.
It's a great plane for FPV and/or UAV. Dynam supply the kit with 4-channel RC (short range receiver). I'm using the Dynam 6-channel set and Corona receivers.
I've put an outrunner motor inside the pod (just what I had on hand) but the brushless kit comes with the motor outside on the back end of the pod. It's noisier than the EasyStar with the hard plastic mount. The ailerons are a bit small for anything but a light breeze.
The brushless version flies great. Loaded with gear it gets heavier and faster but still flies great. Yesterday I was flying in 20-30 KPH winds and at times ground speed was backwards at low throttle.
Paul
Comment by Eye-in-the-sky on October 5, 2009 at 7:40am
I fly one of these and they are only $59 each. The Cloud has alot of room in it and is robust.
I am using it as a testbed for a camera first.
This guy in Hong Kong sells it,
http://www.pw-rc.com/product_info.php/cPath/67/products_id/1550?osCsid=oqdr19jpqkhaa1ifqihh8vk0k2
Has any member used this as a UAV yet?
Admin
Comment by Thomas J Coyle III on October 5, 2009 at 3:33pm
Eye-in-the-sky,
After checking out the Clouds Fly on the linked website, I find it hard to believe that there is a lot of room in the Cloud fuse as the servos are inboard and the battery will take up room in the nose. Also the Cloud is temporarily unavailable according to the website.
Comments?
TCIII
Comment by Peter Meister on October 5, 2009 at 3:40pm
We should get some DIY funds together, and build a mold for our own flight platform. :) - I would throw money into that in a heartbeat. Then we could pump these out on the cheap :) Any takers....How hard can it be to do this. I can CNC these planes, but it would be better to do it with a mold IMHO.
Comment by Michael Donat on October 5, 2009 at 3:52pm
That would be a great idea!
I dont want to steal it from you, but post a new blog about it.
maybe they can set up a paypal donation link and sooner or later be able to create a standard "DIY Drones" model that would be designed specifically for UAV use, making it roomy yet able to perform and sell it in the "Store" tab.
Comment by Brian Wolfe on October 5, 2009 at 3:56pm
I'm using the Clouds fly as a UAV test bed for my PicPilot. Overall I'm very pleased. I've certainly punished it and it has always come back for more. The stock airframe is not as spacious as the EZ, but I cut a door on the bottom of the fuse right under the wing (very close to the CG) and was able to neatly fit the PicPilot right in. That left the whole nose for battery so I'm running a 2600 LiPo. The airframe could stand to be stiffened up with some carbon rod as a full throttle burst will cause some tail wag, but I've been living with that so far. The servos are bottom of the line, but functional. I've stripped two so far after some major impact with the ground and just swapped them out for higher end models. The speed controller seems to be well made, and the motor is a cheap, noisy but functional outrunner. It's hit and miss. I know some people had to swap the motor out instantly as the magnets come unglued, but so far mine has hung in there.
Overall I would recomend it especialy when you consider the cost, but be prepared for some swapage of servos and possibly a motor early in the game. I'll try to post some pics if I ever get unburried.
Brian
Comment
