Comment by William Wegenast on February 26, 2012 at 10:17am Are there any wire diagrams/instructions for wiring this to the Hitech Spectra module? I'd love to put this on my Aurora 9.
Comment by Andre on April 22, 2012 at 1:15pm anyone using it on a Hitec Aurora9 radio with optima9 Rx?
Comment by Paulino M. Lacap Jr. on May 9, 2012 at 4:40pm How do I connect the amplifier with the JR 11 Zero with 2.4Ghz module? Thanks.
Comment by Jordan Tolentino on May 16, 2012 at 5:14pm
Comment by Mark on May 25, 2012 at 9:23pm Purchased and installed this setup with the stock antenna on my DX6i and flew less than 200 yards away but pretty much straight up and lost signal with my Twinstar. Any idea on the area of coverage with the antenna that comes with this setup? I'd like to have a rough approximation of the shape of the transmission coming off of this antenna so I can prevent loss of connection.
Comment by Vernon Barry on May 26, 2012 at 1:16am It's a fractional wave dipole so it makes a doughnut shaped ring of semi omni-directional antenna.
http://en.wikipedia.org/wiki/Dipole_antenna
Inside the black plastic tube, there is the center lead of the coaxial cable wire going up a defined fractional length of the wavelength (1/2, 1/4, or 1/8th), and an equal length tube is facing down back over the coax right at the solder joints in the middle thus one pole is up and one pole is down so the doughnut surounds the antenna in the vertical plane.
Comment by Vernon Barry on May 26, 2012 at 1:29am And sorry, that picture isn't perfect, the doughnut doesn't float above the antenna, it's centers on the antenna in between the upper and lower leg of the dipole.
http://martybugs.net/wireless/rubberducky.cgi
Comment by Vernon Barry on May 26, 2012 at 1:38am I need to add, do not forget the receiver antenae is JUST as important, thus it has a similiar plane and window of acceptance. Ideally, the receiver uses multiple antennas, for diversity and each one occupies a different plane.
http://www.spektrumrc.com/ProdInfo/Files/SPMAR8000-Manual.pdf
Comment by Mark on May 26, 2012 at 12:37pm thanks for the info,
Another concern was the range test I performed using the normal procedure with the Dx6i, however with the booster on I only got 15 paces away before I lost signal. Does the 1w booster somehow interfere with the normal rangetest mode in the Dx6i?
Comment by Vernon Barry on May 26, 2012 at 12:55pm I would say yes, meaning not that it specifically interferes with that test, but rather you have a major mismatch somewhere in your setup. Adding an amplifier is no trivial task. Just like when you turn an audio amp up too loud and it distorts, the same thing can happen with adding an amp here to RF.
You need to do some analysis using at least a scope and maybe some high end radio test equipment.
I know you think it's plug an play, but clearly you do have a range problem (you lost it once) and need to figure out which part of the system is not performing. It could be the amp, the antenna, the connectors, the cables and so forth.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
139 members
312 members
678 members
117 members
Powered by
