How to boost your 2.4Ghz Spektrum/JR Transmitter signal!
I love my Spektrum Dx7 and my 2.4Ghz JR XPS9303 and i refused to trade its solid rock performance by a 72mhz radio just to increase range of my FPV/UAV. So in collaboration with my friend JB we find out the cheapest and secure way to amplify the signal, it even works in some Futabas and virtually with any 2.4Ghz radio, but some modifications are required. Lets see some options:
-Spektrum Dx7 this is the cheapest solution for a very reliable 2.4Ghz radio, i used it for about a year and i never had any signal glitch (unless i fly beyond 2000 feet). The problem with this one is that you have to modify it, you need a SMD to U.FL adapter, drill a hole in the side of your radio and just connect and screw the adapter, no soldering required. If you have more than 5 hours of experience with Legos your qualified to do this job. Then you just need to connect the booster. The one in the picture (middle) is already modified.
-If you have the awesome JR radio but is 72Mhz you can buy the Spektrum 2.4Ghz module and just insert it in the back of your TX, personally this is my favorite setup. It's a good deal because includes a $99 dlls receiver for free! Note that JR TX alone cost around $600 dlls, but you can get it for less, i got mine for 300 bucks with Spektrum Module included on R/C Groups =P. Remember you are looking for the JR XPS9303.
If you have one of the fallowing Futaba radios:
7U Series Radios
8U Series Radios
8J Series Radios
9C Series Radios
9Z Series Radios
FN Series Radios
You can just go and buy the Spektrum 2.4Ghz module, easy and with no hassles. It's also a good deal because includes a $99 dlls receiver for free!
One of the advantages of the Spektrum receivers is the build in diversity system, you can even buy one with 4 satellites like this one, or buy a super tiny, tiny setup like this one, or the traditional one.
The diversity is crucial to have a reliable link when you are flying far away, also Spektrum has a receiver for Carbon Fiber airplanes (Carbon Fiber blocks RF signals).
The idea is to have the best reliable hardware with an SMA connector and the SMA extension cable, after that you are ready for the final step: Get an amplifier. But we are talking about a few hundred dollars here, if you get the weakest one of 100mW it will cost you around $150 dlls. This is not pocket friendly in my point of view. So again our Asians friends come to the rescue, after making some research around the net I've found on eBay and a home Wireless Amplifier, so i decided to give it a chance and i bought it for 60 bucks including shipping! Wow that's a good deal! The one i got is this one.
Note that the amplifier needs 6Volts to work, you can get a cheap 6V power regulator from here and just make the adapter. A 3 Cell LIPO is enough to supply it for a long time.
After receiving the AMP i did some tests, here are my results:
Before using the amplifier, i was able to fly around 3000 feet away (~1 km) using a 900Mhz@500mW Video transmitter. I never lost the video signal, only the radio link...
Using a 1.3Ghz@1Watt Video transmitter i was unable to fly more than 2000 feet away (~600meters). So the 1.3Ghz Video transmitter reduces my 2.4Ghz Spektrum range...
Then i got my cheap Asian amplifier and using a 2.4Ghz Patch Antenna i was able to fly around 2.6 miles (4.18Km) away without a single glitch, but i was unable to continue because now my video was causing me problems, hehe!
Not bad at all! Honestly i don't need more than 2 miles of coverage, is really a long way for an EasyStar. In conclusion the maximum range for my setup still unknown, but the range achieved is more that 2.6 miles and the +2 extra miles of coverage gained for less than $100 dlls is really a good deal for me!
Now just remember this:
-The range will be different in other setups.
-Never turn on your radio without antenna.
-Never turn on the Amplifier without antenna.
-Note that in some country's this amplifier may be illegal.
Thanks for watching!
Comment by William Wegenast on January 2, 2012 at 11:08am
Can this be fitted to the Aurora 9?
I am looking for a way to boost the transmission from my Aurora 9. I know I could something like Dragon Link but, for now I'm looking for something to just boost the signal from the A9 Tx.
Comment by dudz on January 4, 2012 at 11:29am
Is there one available for the "Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver)"
Comment by William Wegenast on January 4, 2012 at 1:01pm
Anyone know if this will work with a Aurora 9 Tx?
Comment by Thomas Rutter on January 11, 2012 at 5:21pm
Ditto on the A9
Comment by William Wegenast on January 11, 2012 at 8:55pm
I know what you mean. No one has any advice on this.
Comment by Thomas Rutter on January 12, 2012 at 12:25am
I just saw this today, and joined today. Been thinking about it.
The only way to make this work with an A9 would be to bust open the case of the Spectra module,
desolder the antenna lead, and attach an sma cable there with a male end on the other end.
There is some talk on the rcgroups A9 thread about a different, faster module, the xps, that fits it.
Do you lose telemetry? Does it have the proper connector? Will find out more.
Jordi, great find, something I'd do. Very cool.
Comment by William Wegenast on January 12, 2012 at 1:31am
The A9 has a module on the back of it. This so the user can 2.4GHz or 72MHz modules. I would imagine there is some way to make the Dragon Link plug into this port. But, I'm not sure. I'm hoping that someone has done it and has some advice for or instruction for some like me. :)
The only telemetry I've used is the SPC port on the Rx to get voltage for low voltage alarms when flying my heli. More accurate than using the timer. ;)
Something similar:
http://www.youtube.com/watch?v=Z6CzSxTMIic
http://www.xtremepowersystems.net/proddetail.php?prod=XPS-A9
http://innovatorfrance.forumactif.com/t212-questions-pour-piloter-i...
Comment by Thomas Rutter on January 15, 2012 at 9:24pm
The xps module only fits the old optic tx's. Bummer
Comment by William Wegenast on January 15, 2012 at 11:27pm
I wonder if you could just wire it into the port and velcro the module to the back of the A9.
Comment by Colin Bouriquet on February 2, 2012 at 2:57pm
Jordi : why one on each side if it says it's bi-directional ? Isn't it enough with one plugged on the GCS side ?
Comment
