Q Brain 4 x 20A Brushless Quadcopter ESC
The Q-Brain incorporates 4x 20A speed controllers in 1 device. All motor leads are pre-installed and are terminated with 3.5mm bullet connectors. Leads are 25 cm long which means that you can use this controller with frames up to 60 cm. It operates on 2-4 cells lipo and 5-12 cells Ni-XX (anyone still using these). Refresh rate is over 400Hz.
Weight of the speed controller is 112 grams and dimensions are ~70x62x11 mm. The Q-Brain is probably very similar to the Hobbywing Quattro ESC.
Advantage: Easy install
Disadvantage: If one of the esc's dies you can't use it with a quadcopter anymore (get a tricopter!)
More information on the Hobbyking site
Note: If you are using the Q-Brain with a KK2 board, then S3 (the white cable) has to be connected to M1 on the KK2 to power it.
Comment by Rob_Lefebvre on May 14, 2013 at 1:17pm
Gary, Hobbywing starte with a 20A, and continues to make the 20A.  The 25 Amp is relatively new, and not many people even carry them.
Comment by Crashpilot1000 on May 14, 2013 at 1:22pm
If this is like skywalker quattro 20 than you can flash BLHELI. SimonK is for atmel. I realy like the sil-chip / blheli combo, anyways.
Comment by Gary McCray on May 14, 2013 at 1:24pm
Hi Robert, yes I noticed that after I put in the response, I also noticed that HobbyKing says that you can use their programmer with their version whereas no such option is listed for HobbyWing ones.
Hard to find anybody not in China or Hong Kong that carries any of them unfortunately (even EBay is from China).
I wish HobbyKing carried more of their multicopter stuff in their US warehouse.
Comment by Jed on May 14, 2013 at 8:14pm
OK, I have been wondering when somebody was going to make an all in one speed controller board. Now all they have to do is to put an full digital I2C connection on it and get rid of the PWM signal for speed control and gain current, voltage, and temperature status fed back from the board. (SIGH) Maybe Someday. . . .
Comment by Bill Bonney on May 14, 2013 at 9:12pm
@Jed: I'm not sure I2C is going to give you speed you are expecting. PWM is quite effective at tranmisting a new value from the controller with good resolution, you update the motors every 2000us being parallel. I2C is serial, using 10bits per byte sent. 2bytes for each message for the same resolution. Then you have multiple devices on have same bus. All competing increasing latency of each control packet to the motors.
But, I agree, in having a port like i2c, to get non time critical information back and to configure the speed control behavior would be awesome... I never remember how many beeps mean what :-(
Comment by David Walsh on June 22, 2013 at 3:35pm
I've got one of these cracked open right now.  It does seem to use Silab chips and there seem to be four sets of programming pads.  I'm pretty new to this so someone else can probably shed a little more light on it.
Comment by Artem on January 27, 2014 at 4:41pm
Hey, since you'be taking this beaty apart coulf weight how much it weights without wires and without its enclousure? I among many other people would greatelly appreciate the effort!
Comment by Philip Price on February 12, 2014 at 11:33am
So did anyone flash this with Simonk?
Comment by Artem on February 12, 2014 at 11:39am
silabs not atmel chips,not simonk but blheli.... google it.
Comment by Philip Price on February 12, 2014 at 11:40am
will do....cheers
Comment
