New 3DR Products: Y6, X8, FPV kit, and APM 2.6
Announcing our new product listings for mid-summer 2013!
 _______________________________________________________________________________________
3D Robotics Y6 and X8 Multicopters - RTF and Kit
We released the Hexa-to-Y6 conversion kit a few weeks back, and now the complete Y6 DIY package and Ready-To-Fly  are available. A Y6 design is able to withstand a single motor out scenario, provides a more open and stable view for cameras, and doesn't weigh as much as a traditional Hex (because it uses less parts). It features folding arms to make ground transport a painless affair. This is our new go-to multicopter at 3DR: better performance than a quad at about the same size!
If six motors aren't enough for you, there is now the X8. With the same coaxial motor design as the Y6, but with four arms. This brute is amazingly compact, it's actually smaller than our quads in the front to back dimension, due to the wide angle of the arms. This is the platform to choose for flying your heavy camera and gimbal setups. The redundant nature of this vehicle is a valuable trait when carrying expensive gear or flying over difficult terrain. This vehicle can lose a motor and remain in a stable loiter with almost no disruption .  The 3DR X8 is available ready-to-fly only at this time.
APM 2.6 and 3DR uBlox GPS with Compass
APM 2.6 is the same APM 2.5 you know and love, but with one valuable change: this revision of the board has no onboard compass, which is designed for vehicles (especially multicopters and rovers) where the compass should be placed as far from power and motor sources as possible to avoid magnetic interference. (On fixed wing aircraft it's often easier to mount APM far enough away from the motors and ESCs to avoid magnetic interference, so this is not as critical, but APM 2.6 gives more flexibility in that positioning and is a good choice for them, too). This is designed to be used with the new 3DR uBlox GPS with Compass, so that the GPS/Compass unit can be mounted further from noise sources than APM itself.
Note: APM 2.6 requires an external compass for full autonomy. If you are using APM 2.6 with a GPS module that does not have a compass sensor, you must use a stand-alone external compass. We recommend this one with this cable.
New GPS shown as it comes, in a nice enclosure
The board, inside the enclosure
You can also use the new uBlox GPS with on board magnetometer (compass) with your existing APM 2.5, To modify your board, follow the directions here.
_____________________________________________________________________________________________
FPV Package
If you have been wanting to add first-person-view (FPV) capability to your vehicle, our new FPV package gives you everything you need in one kit (including batteries). All connectors have been built in the factory and designed to give you an easy plug-and-play experience -- no soldering required! On-screen-display is provided by our MinimOSD board for real time data telemetry. This is an important safety and convenience feature for anyone flying FPV.
All of these items are available for order immediately.
The FPV kit is ready for shipping today.
The Y6 DIY package and APM 2.6 will ship on July 15th.
Note: RTF Y6 and X8 units will follow the normal 1-2 week turnaround. You'll find those and more on our new RTF store here: http://rtf.3drobotics.com/
Comment by Todd Spurgeon on July 13, 2013 at 8:03pm
Does anyone have any idea how much distance someone could reasonably get with the FPV kit being sold in the store. I am very tempted to buy it but wanted an Idea of the range I could get with the stock antennas before I purchased. I am assuming under unobstructed conditions.  PS: thank you guys (3DR Robotics) for doing this, it is helping out a lot of people like me wanting to build fpv into their systems.
Comment by Tash Hepting on July 13, 2013 at 9:33pm
Joshua,
Thanks for the info, especially the video - very clear explanation.  I have a couple more questions (of course, always with the questions)...
Is the 12min flight time on the Y6 with the 600g payload?
I've got a special camera that's 515g without a gimbal mount.  I'm kinda thinking that's going to be pushing it on the Y6, especially if I want longer flight times.  Thought?
Thanks,
Tash
Comment by Leszek Pawlowicz on July 13, 2013 at 9:34pm
What's the recommended battery type and capacity?
Comment by Stone1295 on July 13, 2013 at 10:01pm
I don't know if it's the recommended battery type and capacity but Josh came up with a parameter file for the Y6.  If you are using blue motors (the 850kv ones) then you can run either a 3S or a 4S with 4000mah to 6000mah battery.
http://ardupilot.com/downloads/?did=57
Not really a recommendation but it gives you a general idea of what other folks are using.
For me, I use a 3S 5000mah and get about 11 minutes of flying depending on how much of my flight is hovering or flying a waypoint mission.
-Mike
Comment by DVS QUAD on July 14, 2013 at 2:35pm
 Peace Everyone.
    Nice line of new products.  One question though.. is there any plans to come out with some type of conversion kit to make my 3DR quad an X8?    If I had a $1000.00 bucks to buy the RTF I would, but I don't.   If not a kit, could someone help me out on how to change my quad.  PDF?   anything
  Thank you kindly
Comment by Stone1295 on July 14, 2013 at 6:04pm
Hmm... I can't edit my post up above so I'll post up a correction here:
I'm actually getting 8-9 minutes of flight time on my Y6 using a 3S 5000mah battery.
-Mike
Comment by Joshua Ott on July 14, 2013 at 9:18pm
A good rule of thumb is 1 amp/hour of battery capacity per motor, so 6 amp/hours for the Y6. I think that 4s is always the way to go.
DVS Quad, The tricky part with the X8 is the power distribution board, the RTFs are using two of the quad PDBs, but I think we are going to design one just for the X8. Then we will most likely start offering a kit for that configuration.
Comment by Joshua Ott on July 14, 2013 at 9:27pm
Tash, what gimbal mount are you thinking about using, how much weight?
Todd, 1.6 km is a good estimate, but as you know there are many variables at work with rf. I recommend you watch Alex Greve's video series, from that you can get a good idea of what a basic system can do and what variables to play with for building up a more advanced system. With our kit as a starting point you can easily add different antenna types and modify the performance to suit your needs.
Leszek, 6 amp/hour 4s is a great choice for the Y6, 8 amp/hour 4s for the X8.
Comment by Tash Hepting on July 14, 2013 at 9:35pm
Joshua,
I haven't looked at Gimbals at all yet.  I'm a photographer that is just getting into RC & multirotors for a specific project.  I've been reading, practicing with a v959 for the last several weeks (and have broken/repaired/rescued it a few times now), and am just now getting to the point where I think I'm comfortable enough to think about getting what I need for the project together.
It looks like you use to sell a gimbal on the Hexacopter, but I don't see that option on the X8.  Do you have any suggestions on Gimbal choices?  The camera is an NEX-5R from Sony, and I have a special "big honkin" lens on it that is what is pushing the weight up.
I also noticed that the battery/charger bundle offered on the X8 seems... light.  4200MmAh 3S batteries?  Seems like it would be better to offer something with better flight time, or a couple of kit options for balancing payload vs. flight time.
Thanks,
Tash
Comment by Tash Hepting on July 14, 2013 at 10:17pm
Joshua,
Also, do you have any pictures of the X8 with the legs folded?  I didn't seem any on the website.
Cheers,
Tash
Comment
