Skywalker is now in a new version made of EPO foam. Much stronger foam.
Length: 1180mm
Wingspan: 1680mm
Wing Area¡G35.5dm2
Wing Loading¡G36.6
Recommendation
4 x 9g Servo
3S1P 11.1V 2200mAH-5000mAH
Motor: 2215-1200KV or 2815-900KV
Propeller: APC-9045E 9060E
I think this platform could be the replacement for the smaller Easystar if it's possible. What do you think?
Skywalker is now in stock! This is not the EPS foam, this is the new EPO version - much stronger foam.
See more on this Skywalker FPV UAV platform.
Comment by Brian on October 23, 2010 at 4:31pm
Comment by Abe on December 3, 2010 at 2:17pm
Comment by Brian on December 3, 2010 at 3:31pm
Comment by Hein du Plessis on August 2, 2011 at 11:29pm Well, mine's on it's way!!!!
Please could someone recommend a battery pack for maximum fly time??
@Hein, I use a 5Ah 4S battery, and typically fly for a bit over an hour, but I tend to fly pretty gently
Comment by Hein du Plessis on August 3, 2011 at 2:45am Fantastic Andrew - would you say one could fit 2 x 5mAh and push it to 90 minutes plus?
Comment by Hein du Plessis on August 3, 2011 at 11:34pm I found some data on rcgroups:
3000mAh: 30 minutes
6000mAh: 50 minutes
10000mAh: 80 minutes break even
12000mAh: 80 minutes no more benefits
14000mAh: 75 minutes starts descending
From npole's post on http://www.rcgroups.com/forums/showt...h#post18069450
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
184 members
11 members
182 members
1290 members
Powered by
