Comment by Coby on January 8, 2011 at 11:16am
Comment by Alexandre Girard on January 14, 2011 at 6:14am For info, the "Flash Description File" is stored in C:\Program Files\u-blox\u-center\content\flash.txt
Another important thing that occured for me during the flash:
Comment by Jarco den Dekker on January 30, 2011 at 6:23am Hi,
I did everything according the tutorial and updated everything in the ublox, nevertheless I have the GPS on the uCenter outside the house and after one and an half hour still no fix
What am I doing wrong?
Comment by Michael Manuel on January 31, 2011 at 6:29pm I am currently running Windows 7 on my machine. When running under the "classic" theme, uCenter seems to run fine, but are there any operational issues that may rise? I do not have XP mode on my machine.
My real issue is that I have not been able to connect my GPS (ublox 5) at all, nor has it ever acquired signal. Here is some background:
- FDTI cable/adapter purchased from diydrones store
- Ublox 5 purchased from diydrones store
- GPS has never acquired signal in use with UAV DevBoard
- GPS is not recognized by uCenter at all (despite being recognized in the device manager as being connected to COM5, baud rate of 38,400), thus firmware cannot be updated
I've followed the instructions, but still cannot acquired signal, nor connected to uCenter. Any ideas or similar problems?
Is the problem rooted in the fact that I am running Windows 7 (in classic theme)? If it is, why can't the GPS connect even when attached to UBD? May it be a defective unit? Am I not using the correct COM or baud rate?
Thanks,
Mike
Comment by John on April 3, 2011 at 2:08am Hi Chris
I am looking for the flash definition file that needs to be loaded with the firmware update. I try to update the firmware to v6.00 in order to load your config file. My upload screen all goes well until it looks for the flash definition file and then the screen goes red and the firmware is not flashed. I have used Jordi's older post on setting up with v5.0 as i dont need to update my firmware, and loaded the config file he recommended, changed the setting that he recommended and the ublox get satelite signal but no sat lock. What is, or what does the flash definition file do when updating the firmware of the Ublox LEA 5H? Also, do I need to set the GPS to work with satellites for Africa, Specifically Cape Town where I stay.
Thanks John
Comment by John on April 3, 2011 at 8:42am
Comment by devangel77b on April 17, 2011 at 1:01pm
Comment by Bijay Adhikari on May 21, 2011 at 1:12pm
Comment by Giuseppe on July 28, 2011 at 8:06am Good afternoon,
I've got a Ublox LEA-5H-0-009. I've tried many times, but I'm not able to fix the satellites.
I updated the firmware and tried all the solution mentioned in the forum, but nothing…seems that it works, but the antenna does not catch the satellites.
In attached you can find the ublox center snapshots.
Have you got any other solution?
Thanks, Giuseppe.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.185 members
6 members
129 members
87 members
24 members
Powered by
