Ardupilot as OSD WITHOUT additional hardware (NO LM1881)
BaroneOSD is a PAL video overlay impression WITHOUT additional hardware required (NO LM1881 Sync generator).
Use only 3 pin:
D1 (USART TX) used to pump pixel in the video connected with a 330Ohm resistor to D6
D6 (AIN0) Video in/out, connect here you camera or radio TX.
D7 (AIN1) 0.3V Voltage reference (you can use a partitor resistor)
http://www.elenafrancesco.org/arduino/
Comment by Francesco Ferrara on March 16, 2010 at 3:32am
tvpal generate a TV Signal (full with VSYNC and HSYNC).
baroneosd overlay text over a PAL signal.
Comment by Rana on March 16, 2010 at 3:43am
Would it not affect the performance of stabilization / navigation by ATMega328 of Ardupilot ?
Comment by Francesco Ferrara on March 16, 2010 at 3:51am
There are some work on the code to integrate it in ardupilot, but I think that is possible.
This program is interrupt driven, and with only 1 line to draw (8 pixel) I think 64us per line, 1ms per frame (50hz) 1/20 of the time consumed to draw.
Comment by Rana on March 16, 2010 at 4:05am
As a standalone osd based on ATMega328, I suggest you a perfect suggestion and that is base on Openlog hardware. It's a small module based on ATMega328. While Openlog receiving data on uart, can handle this task happily.
OpenLog can be easy connected in parallel to X-Bee and work hapily
Comment by Rana on March 16, 2010 at 4:34am
Here is the lates HEX file, firmware modified by me to support bauds 2400, 4800, 9600, 19200, 28800, 38400, 57600, 76800 & 115200. OpenLog.hex
Comment by Francesco Ferrara on March 16, 2010 at 5:27am
Did you mean this ?
Comment by Tim McMahan on March 16, 2010 at 5:32am
Here is a standalone unit based on AVR, perhaps some of the info there would helpful in this? Its based on NTSC. The same guy has a HAM radio telemetry system as well.
Tim
Comment by Rana on March 16, 2010 at 6:48am
Comment by Francesco Ferrara on March 16, 2010 at 8:16am
To use the analog comparator, PD6 PD7 (AIN0 AIN1) are needed, but are not avaiable on this implementation sorry.
Comment
