I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
And here's the impressive work of the AeroQuad team:
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature List
6 Degree of Freedom IMU stabilized control
Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
GPS for position hold
Magnetometer for heading determination
Barometer for altitude hold
IR sensor integration for obstacle avoidance
Sonar sensor for automated takeoff and landing capability
Automated waypoint navigation
Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
On board flight telemetery data storage
Mounted camera stabilization capability
Wireless command & telemetry for long distance communication
Capability to fly in "+", "x", hexa and octo configurations
Battery level detection
User configurable LED flight pattern
Capability to use any R/C receiver
ArduCopter Configuration and Ground Control Software
Realtime graphs of flight data
GUI for configuration of PID and other flight parameters
On Screen Display integration
Waypoint programming using Google Maps
Mixertable view to auto configure "+", "x", hexa and octo configurations
Software Roadmap
Initial baseline using Jose Julio's v3 software
Provides absolute angle PID flight control
Obstacle avoidance
Waypoint navigation
Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
Emphasis on developing new capability into easy to use C++ libraries
Integrate user defined EEPROM storage capability
Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
Integrate AeroQuad Configurator for external software configuration of ArduCopter
Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
Integrate AeroQuad rate PID control
Integrate mixertable configuration for multicopter configurations
Integrate AeroQuad camera stabilization
Integrate I2C motor control
Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
Sebasatian, that is not actually 100% correct. It is possible to remap broken channel but it needs a lot more than just changing those few lines. There are a lot internal timers that we are using to generate fast PWM signals and others. Most of those timers and ports are defined in our Libraries. So you need to change timer bits and prescalers too or it won't work properly.
Richard, if you damaged mux. Eg it sounds that you hit ESC connector one pin too up. You can shortcircuit that mux pin directly to main MCU. I would rather override mux than play with libraries and their preconfigured timers.
Thailand journal, next morning: UFO in the Bangkok sky last night
People saying... It have a strange sound of wasps... it's scary...
It have blinking lights.. It blinked slowly* and so, it started to blink quickly** and then it gone fast until disappear!
Ok videos are not the best ones but it gives idea how it looks when you have LED's on it. Furthest distance that I flew it today was about 50m away and 20m of altitude and it just glows... Tomorrow I will get some more LED's (if our shops are open again due holidays) and put few on that battery mount too. I still have some PID tunings to do on stable mode so mainly been flying on Acro but even that both modes works just great. On Stable is levels really nicely tho yaw I still have a bit "springy" feeling but like said, i have not tuned it yet and all settings are on their defaults.
Nice demos! As I mentioned, I am tuning mine today. I've already dug one prop into the ground on a wobbly landing this morning... LOL! I think I will turn down the Tx influence on the APM rather than ad expo on the Tx. Thoughts on which is best to do?
Also, flight is a bit spongy, so I am also playing with gains/PID values a bit. It is possible that the ESCs I chose are not fast enough at reacting to Arducopter's needs... We will see.
Well I am using full default values on all of those videos and only time when I have spongy feeling is when I rotate my quad in stable mode and even on that it's not bad. ArduCopter frame that I fly is 24" from motor to motor eg. bigger ArduCopter. I do have C2830-1000kv engines on it and total flying weight was 926 grams or so.
ESCs are ArduCopter ESCs that we plan to use in future releases, motors are still a bit so-so. They are really nice looking mots but like most of people can hear from videos, one motor has some bearing problem so it looks like that provider has some quality problems... no thanks, next please :)
John, didn't you know. Props are meant to be flying, not making potato fields ;)
You should check your flying modes and also check xmit factor. You can play with your transmitter gain too on Configurator. My setup is that I have a bit of transmitter gain in use on ArduCopter it self and then I can also switch dualrates from my radio if i want to do really precise flying. All vids was done without D/L and transmitter gain was 0.8 if i remember correctly.
Season Two of theTrust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.
