Features include:
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!
(We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
I cant find the correct program to read the Euler angles from the IMU then to move the servos,i can control the servos easily , and upload the code too, but still cant know how to read the valuse from the IMU??? BTW the IMU is properly connected to the ardupilot and the indicating leds are ok, but I eaither cant read or use the Euler angles from the IMU nor see the values on the serial monitor ...... Can u help me to figure out the problem plz...???
Jonny: Yes, it's easy with the Mission Planner. Please see the manual for more. You can use 2.4 Xbees, but the setup process is a bit more complicated (and the range shorter) than the 900 ones we recommend. It's in the manual too.
Hello Jonny,
You can get the info on 2.4 GHz Xbee kits here in the EU we are not allowed to use the 900 Xbees :( They do not have the range of the 900's but work fine for LOS flights. The Telemetry Kit can be found here.
Regards
Martin
Comment by Bill on September 16, 2011 at 5:44pm Are there plans to release a new version of the hardware or is it mature and now only the software is being developed?
Thanks, Bill
Bill, we release new hardware versions (memory or sensor upgrades) approximately every six months. That's been true for three years and will continue as far as we can see.
Comment by Bill on September 17, 2011 at 10:09pm Thanks Chris, I'll wait until everything else is finished and buy the APM last.
Jonny: never heard of that one, I'm afraid.
Jonny, where did you find that manual??? That's dating back to 2009 and the very first ArduPilot!! That's a totally different product, long ago discontinued.
Seriously, how did you even find it? I didn't even know there was still of copy of that ancient manual out there.
Comment by Björn Pettersson on September 19, 2011 at 12:07pm Links broken? Tried to access the wiki, but it seems I can't (no menu to the left)
Bjorn. Thanks for the catch. Now fixed.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.87 members
1298 members
106 members
47 members
51 members
Powered by
