Reach is the next product from Emlid.
It's a RTK L1GNSS board with and IMU powered by an Intel Edison board (using linux - integrated WIFI and BT LE)
The module will be release around April at a price between 140-180$ (TBA).
Features
  • Intel Edison
  • MPU9250 9DOF IMU
  • U-blox 8 Glonass/GPS/Beidou with raw data
  • Hot-start supercapacitor
  • USB OTG controller
Specifications
  • MCX antenna connector
  • Bright red/yellow/green LED
  • Extension 7-pin port with 3.3V logic level:
  • 1xUART, 1xI2C, 1xGPIO, 1xPPS
  • Compact size: 26 x 45 mm
more info http://community.emlid.com/t/reach-rtk-module-availability/212
Comment by Mikhail Avkhimenia on March 20, 2015 at 6:46am
@John Dennings
In good environment the coordinates can be ~1-2cm accurate.
RTK won't work in a hangar with a repeater.
Comment by John Dennings on March 20, 2015 at 10:37am
Ok. Thanks for the info! Can't wait to try some ...
Comment by arga firmansyah on July 8, 2015 at 2:47pm
Just wondering, i thought piksi is doing the same thing as this reach. What would be the difference between the two?
Comment by Ralph Pendergraph on October 19, 2015 at 6:00am
Hi, I am a surveyor with a fair amount of GNSS experience and I am curious as to how you achieve cm accuracy with only L1.  Is the data from the Reach post processed?  Do you have plans for multi frequency receivers and antennas?  Thanks for your response.
Comment by Stmpngrnd on October 2, 2016 at 4:44pm
Selling an extra Emlid Reach RTK Kit if anyone is interested.  Only used for bench testing and setup...never flown! http://www.rcgroups.com/forums/showthread.php?t=2750520
Comment
