Help wanted! Here is the latest firmware revision that fixes the longitude issue. If you are one of those that are having problems please try this new version:
AXN1.30_2278_3329_384.1151100.1_binary.bin
Let me know your results.
Instructions for reloading your firmware are here.
Tags: issue, mediatek, mtk, position, problem
Comment by P D on October 7, 2010 at 1:00pm
Hi Joirdi, I'm having some problems updating the GPS Firmware (my Lon values are completely out of range, Lat is O.K.). Now I don't have an FTDI cable, so i'm stuck with the pass through method using the script in the manual (attached). I am using the APM.
Which baudrates should I set in the script, and what baud rate should the flash tool be communicating with?
I Tried 38400 for the APM (IMU?) and 9600 or 115200 for the GPS. Set the flash tool at 38400.
Result: [Flash Download],Fail!!(Download) DL_HANDLE error code,[Finish]
void setup()
Serial.begin(38400); // FTDI; this is the speed at which the IMU board is communicating with your PC
Serial1.begin(9600); // GPS; 9600 is the usual default for NMEA GPS modules
delay(10000);
void loop()
if (Serial.available())
Serial1.write(Serial.read());
if (Serial1.available())
Serial.write(Serial1.read());
Comment by AS on October 13, 2010 at 8:46am
I got a mediatek with an adapter, but want to use it with USB, any ideas to make it work?
Best Regards
AS
Admin
Comment by Thomas J Coyle III on October 13, 2010 at 9:02am
Andre,
You will have to get serial TTL level to USB converter like the FTDI cable. Jordi sells a MediaTek to FTDI cable adapter. Check the DIY Drones store for availability.
TCIII
Comment by AS on October 13, 2010 at 10:39am
Hi TCII,
Yes, I have a FTDI cable, and it works like a charm, but de Mediatek GPS has D+ and D- ports to direct use with USB, what I wanted is to use the adapter linked directly to a USB cable without the FTDI in the middle. I already cutted the IN and OUT strips and soldered two wire from D+ and D- to IN and OUT pads. But the
Sorry for the bad english :\
AS
Comment by Preston on December 28, 2010 at 1:35pm
I think this firmware update is the root of my problems....however, the update fails every time with the error ...
Fail!!(Download) BROM_CMD_START_FAIL
I am using an APM with IMU. I have loaded the pass through code. This is a show stopper. Any help?
Preston.
Comment by Chris Anderson on December 28, 2010 at 1:43pm
Yeah, I don't think the pass-through code will work with this version. You'll need a proper FTDI cable.
I've updated the manual to make this clear.
Comment by Preston on December 28, 2010 at 6:28pm
Excellent.  I will give this a shot in the AM and post my success.  Thanks for the fast response.  I love open source project!
Comment by Preston on December 29, 2010 at 7:38am
Ahhh the coveted green 'O'! Using the FTDI connection direct to the gps allowed the firmware update to complete. With the new firmware, I am no longer in the Aegean Sea. Welcome back to S.W. Ohio!
Thanks for your help.
Comment by Henry Gan on January 16, 2011 at 11:38pm
Recently just bought a new mediatek gps from DIYdrones. I have connected the mediatek gps with ftdi cable. I run the powerflash.exe as per instructions from the Arducopter googles page. I link to the 115200 baud and correct com port and selected the agent file and ROM file but it will fail the downloading. (BROM_CMD_START_FAIL)...
I have tried changing the baud rate and swopping the tx and rx cable but still fail the downloading.
Any advise?
Comment by Sravan Kumar on March 20, 2012 at 11:15am
IM using MediaTek 2239 GPS with ArduIMU V3. When im uploading the frimware to module i got the error
Please any one can help me?
Comment
