Trex Boom Copter Drawings ready and waiting for machining...
Comment by John Church on September 20, 2010 at 8:14am
Will you have a slit in each boomblock to clamp the booms? Looks like a nice tough design :)
Comment by DaveyWaveyBunsenBurner on September 20, 2010 at 8:24am
Nice!
Comment by Raytrace Nomad on September 20, 2010 at 8:25am
No slit yet , first i try these but if needed cut 2mm each side of block.
Comment by Daniel Gru on September 20, 2010 at 8:46am
Looks nice, exactly what i am looking for actually.
Will it support the "build-up" electrical tower coming on the arducopter, to safely secure ardumega etc?
You may have to be careful by the motors as well, can't see where the cables should go if the motor is attached from the top... or will the motormount be so narrow, that the cables go past it into the boom?
Daniel
Comment by Raytrace Nomad on September 20, 2010 at 8:53am
In testing time i plan to use
small cd cakebox. After testing time i plan to make other floors :)
Admin
Comment by Thomas J Coyle III on September 20, 2010 at 9:46am
Raytrace,
Your design duplicates Rusty's Rad Rotary Rev 7 design which uses TRex 450 booms: http://aglhobbiesllc.com/shop/viewitem.php?groupid=1&productid=2
TCIII
Comment by Raytrace Nomad on September 20, 2010 at 10:15am
Yepp , it looks like.
I think 450 booms are more comfortable. If i not alread bougt 600 boom's i want to use 450 ones. [ cheaper , strong enought and less weight ]
That looks convertable too [ for carrying ]
This is my first design. After test flight i could change worst things and maybe redesign allover ?
After flights i will happy to share plans.
Comment by Daniel NIkolov on September 20, 2010 at 6:41pm
Are you using solidworks to do the modeling or another cad system?
Comment by Raytrace Nomad on September 20, 2010 at 8:50pm
Yes i use Solidworks.
Comment by Daniel Gru on September 22, 2010 at 8:20am
Looked at rustys frame too, really nice design.
Now Nomad, will you have it available in octo or hexa config too?
Will it somehow be foldable or at least fast and easy to detach arms?
Comment
