I designed this baby over the weekend for everyone to have if interested. It should be a very good size for most of your application. I can be built with foam, wood, and composite.
Wing Span: 1.6m
Length: 1.1m (nose to tip of v-tail)
Max Weight: 6kg
Recommend 4 Channels (Aileron, V-tail, Throttle)
Power: .45 - .65 cu.in. or equilvalent electric power
DOWNLOAD ZIP FILE HERE!!!!
Comment by Dave Buckley on November 17, 2010 at 4:03pm
I may not be able to get them off Ryan until tonight (10am here), but I'll get them to you first opportunity and I'll mark them on the plans.
Comment by wayne garris on November 17, 2010 at 4:33pm
cool , keep me posted
Comment by Rana on November 17, 2010 at 6:47pm
During last two years, my own thinking about the belly landing got a 180deg twist after seeing Multiplex Easystar.
Earlier I was also insisting for the landing gear but according to me belly landing is the most safe and convenient landing.
The belly of the plane has to be made slightly flat similar to Easystar and should have extra protective covering.
Tips of the wings should be similar to that of Easystar as such type of wings provide wonderful stability to the plane and are ideal for belly landing planes.
Comment by Dave Buckley on November 17, 2010 at 6:49pm
Thanks for the feedback. I'm sure we'll be able to adapt this for either wheeled landing or belly landing.
You raise very good points.
Comment by Ryan on November 17, 2010 at 10:50pm
Clark-Y set to 12% thickness
Belly landing is just fine with this design. May round off the wing tip or sweep the tips up abit
Comment by Ryan on November 17, 2010 at 10:54pm
No need for wash out, don't think it will be worth it for something this small
Projected max weight is ~3.0kg.
10" prop is fine. Only need .4 : 1 thrust to weight ratio, people flies way over powered!
If you want bigger prop, use 3 blades
I think that for something this small most aerodynamic refinements won't do much justice.
Comment by Richard Hirst on November 18, 2010 at 1:33am
Just a few small changed to an excellent base. I changed the Wing, the Airfoil is a NACA2414 at about 12%, Wingspan 1670 with the Tips added. Changes to the motor area with cooling etc.
It was re-drawn in SW2010 as I plan to add more contruction inside so I can laser cut the parts and maybe make a mould after test flights.
More than welcome the the Files, not sure SW2009 will read the 2010...?
Comment by Dave Buckley on November 18, 2010 at 2:28am
@Ryan - did your version read the parasolids I sent?
Comment by Dave Buckley on November 19, 2010 at 8:33pm
Are we abandoning landing gear in favour of a belly lander?
Bueller?
Comment by Ryan on November 20, 2010 at 11:11am
Well, how's the CFD going?
Couldn't anyone just do a simple flow with Cosmos at different Alpha?
Gear or no gear - that's the builder's choice.
Comment
