HK GCS now supports APM binary and UavDevBoard (Matrix Pilot/Serial UDB Extra)
Recent additions to my GCS include the APM binary stream and the UavDevBoard (Matrix Pilot/Serial UDB Extra) data stream plus playback of UDB text file on the Data File tab. Quad model is also a new addition (many more models coming soon). Screen is now resizable and depending upon the instruments size, either the glass cockpit or 3D model can be clicked and selected as the "big" instrument. Minimum screen size is now 800X400 which should work well on older laptops and netbooks.
Next on the To-Do list is APM 2-way with MAVlink support, Installer and more models. Still hoping to add AttoPilot support shortly.
If you're having problems installing, make sure to run the DirectX download EVEN IF you have the latest DirectX installed. These include additional drivers MISSING from the standard DX installer.
Minimum requirement still includes .NET 2.0, Google Earth and the Google Earth API.
Download the latest here: http://code.google.com/p/happykillmore-gcs/downloads/list?saved=1&a...
Links to minimum requirements here: http://code.google.com/p/happykillmore-gcs/
Comment by Paul Mather on December 29, 2010 at 11:24pm
Marcus, for some reason, I removed the parsing line for the "F2" messages at some point recently. It's back now and should be working....
Comment by Grant Olivier on May 12, 2012 at 8:55am
Hello Paul
I'm also a newby to the scene. I have a simple scenario as follows:
I've set up a UDB4 running MatrixPilot V 3.2.1 to use "#define SERIAL_OUTPUT_FORMAT SERIAL_UDB_EXTRA" in the options.h file. I have attached an OpenLog to the port on the UDB which is successfully logging channels output to the SD card. As I understand MatrixPilot outputs ascii text to the port and OpenLog just logs the data in a text file. Now when I connect the same port (I use the gnd, RX2 and TX2 pins) to my com1 serial port on my windows XP laptop and I connect using HK GCS Lite - v1.3.33 in the Serial Data tab, Raw Data window I keep getting the message IN: Unknown Message: followed by unreadable text. with the field GPS Type: changing between 20% and 35 %.
My questions are:
1) I believe I should see text that I observe in the files logged by OpenLog (for eg. the "F2:T0:S100:N0:E0..."), should I expect this?
2) When I disconnect the serial cable the GPS type changes to 0.0% but I still see the IN: Unknown Message: followed by unreadable text scrolling in the Raw Data view. Should the data not stop scrolling?
3) If what I assumed in 1) is correct then either my communication port is not properly connected (I am just using the UDB GND, TX2 and RX 2 connected to COM1 GND, RX and TX) or HK GCS needs to be set up to recognize SERIAL_UDB_EXTRA messages. If that is so would you please advise me on how I would do this?
Thanks in advance for you assistance
 Grant
Comment by Paul Mather on May 12, 2012 at 10:34am
Grant, I'm not sure I can help you. MatrixPilot is in constant flux to the best of my knowledge. You'd probably have to ask Peter are the compatibility at this point. I also think they were planning on going to MAVlink at some point, not sure how far they made it with that.
Comment by William Premerlani on May 12, 2012 at 10:54am
Hi Grant,
I suggest you repost your question to the UDB discussion group.
Best regards,
Bill Premerlani
Comment
  • X8
    X8
    130 members
