After a long wait we are delighted to finally release our second official firmware for ArduCopter. This code is our intermediate code (code name NG) that is a step towards reconciling with the full ArduPilot Mega framework. The next version (codename ArduCopter Mega, ACM) will be fully compatible. As always, be careful when testing fully new software.
Our development group has been flying this software on many ArduCopters without any problems but still it does not mean that is won't have any bugs, there might be one just behind the corner. Tho we have been trying to nail them all down.
Thank you for whole ArduCopter/ArduPilot Mega teams for this great release.
Always check our latest release notes and test instructions from ArduCopter Wiki pages.
Main new features:
Here's a video of GPS position and altitude hold working:
Quick install notes:
--Download the code and unzip the ArduCopter RC2 folder to your desktop. It will include two folders: "ArduCopterNG" and "libraries"
- Move the libraries folder into your regular Arduino sketchfile folder, replacing the libraries that are already there. Delete all the old libraries folder and copy this one in instead.
- Open the ArduCopterNG.pde file in Arduino and check that the #defines in that file and ArduUser.h meet your requirements. Typically the only one you will need to check are magnetometer orientation (if you're using a magnetometer):
#define MAGORIENTATION AP_COMPASS_COMPONENTS_UP_PINS_FORWARD // This is default solution for ArduCopter
//#define MAGORIENTATION AP_COMPASS_COMPONENTS_UP_PINS_BACK // Alternative orientation for ArduCopter
//#define MAGORIENTATION AP_COMPASS_COMPONENTS_DOWN_PINS_FORWARD // If you have soldered Magneto to IMU shield as shown on the wiki
- Upload software to your ArduCopter electronics
- Run the CLI by changing position of SW2 switch and reboot your APM--towards the servo rails is CLI mode; towards the GPS connector is flight mode. Open the Arduino serial monitor, setting baud rate to 115200 baud and ensuring that "Carriage Returns" are enabled. You should see a command line on the monitor. CLI instructions are here.
- Run and all necessary settings like factory reset and IMU level calibrations along others your might need.
- Make normal flight preparation tests before connecting your propellers
- Fly safe....
Installation and latest information, please do check our ArduCopter and ArduPilot Mega wiki sites for more information.
ArduCopter NG, NG specific details and test procedures
ArduCopter Wiki, for all quad and heli based information and updates
ArduCopter Heli, especially for ArduCopter heli modifications. It is flyable and needs more beta testers.
ArduPilot Mega Wiki, for general electronics related information and also fixedwings
Last but not least, the release code: ArduCopter RC2
Comment by Steve Burton on December 21, 2010 at 9:02pm The problem above was fixed by disconnecting the Magneometer, but any Ideas on the reason that cause the Arducopter not to connect to the Configurator?? Oh and by the way Fantastic Kit!!
Comment by Matt White on December 21, 2010 at 10:29pm
DODY, yes your magnetometer looks correct on the picture, tho you could use 2-side tape to mount magneto. Zipties can cause some extra vibration for it. I also see that you invented another method to mount your ESC. Nice.
I can look to create video of making magnetometer offsets but it's fairly simple procedure, on CLI just type 'c' and after numbers starts to roll. Move/roll/pitch/yaw your quad on every direction untill those numbers are not changing anymore. Usually it takes about 30-60 seconds to rotate your quad enough.
Hello Jani, here a video of Arducopter in flight, configuration tx in mode 1 and programs
beta2, I control it similar with the version rc1, I do not see a difference
with the magnetometer.
Regard
dody
For people who want to see how maggy offset calibration is done, i made a small video to show it along with proper #defines
Check it out : http://diydrones.com/forum/topics/video-arducopter-magnetometer
Dody, yes mode 1 & mode 2 does not have any special difference in software. Only difference is your radio and how stick/channels are arranged on it.
Comment by Steve Burton on December 23, 2010 at 1:13pm Steve,
no, not quite right - actually I think it's all exactly backwards.
so if you were to change the wires as they feed into the white connector...the order should be, from left to right, red, blue, green, yellow.
but on the white connector, you are correctly leaving the two left-most positions empty. this part is correct.
-Randy
Comment by Taylor Cox on December 24, 2010 at 2:44am
Comment by ramboky on December 24, 2010 at 3:26am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1298 members
249 members
183 members
693 members
24 members
Powered by
