DroneePlotter - Drone Flight Log Analysis Tool Works on Web Browser
We are happy to share DroneePlotter -  Drone Flight Log Analysis Tool  with drone comunity to make analyse and sharing easier.
DroneePlotter works on browser not (on server) Just drag and drop the log file . It parses binary log file inside browser instantly with Java scrip, and it works very fast .
It generates flight graphs automatically , also you can  visualise specific flight data on graph and easily share with others, post on blogs, discussion forms.
To share your analyse with others you need to click UPLOAD button, it will generate unique link based on their md5
which means even another person uploads this file,server will generate the same url.
I hope it will make life easier, and your feebacks ,reviews are very welcome.)
https://plot.dron.ee/
Comment by Andrew Tridgell on November 1, 2017 at 1:35pm
perhaps better to communicate trough gitter.im or slack for the FFT which can make things faster ?
sure, which channel? What is your ID ?
Comment by Maksim P on November 6, 2017 at 11:42am
Now you can radomize the gps  trajectory origin keeping the trajectory pattern,or make all the gps data zero before uploading the log file.
"zero/randomize gps" are in the Maps Page.This redits the binary file before upload.Note that, if you are logging since boot(gps is logged even if there is 1 satellite) you should use "zero" instead of "randomize".
Andrew Tridgell  DFT support for the ISBH frames is implemented as well.Menu option is visible  only if the log file contains ISBH frames.
Comment by Maksim P on November 6, 2017 at 11:45am
zero/randomize edits all the GPS,POS,ORGN fmt datas in the log file
Comment by Greg yesterday
Hi, what autopilots do you support? Just Ardupilot or do you support others? I'm really keen to find one for DJI's A2. I want to be able to see copter attitude changes based on stick inputs, for scenarios where there was odd behavior from the aircraft.
Thanks!
Comment
