What are the 5 Top Beginner Drone Kits You Can Buy in 2017 to Learn and Build Your Drone
The prices of drones have fallen recently and building a drone from a drone kit may not save you money but it is still a fun and a learning activity. When you build your drone from scratch, you know what goes where and it helps if something gets broken. You can quickly buy the replacement and fix it. Drone kits are therefore still popular for amongst many drone enthusiasts. In this article I have tried to list five top drone kits in the market you can buy and build your drone.
1. F450 ARF Drone KIT from DJI
This is a starter drone kit. Good frame design with sufficient space to mount the accessories. The frame is available in three different colors. The accessories you have to buy separately are the radio controller, gimbal and camera and the batteries. There are helping tutorial videos available which will assist you in building your DIY drone.
2. LHI250 Quadcopter Kit
 This is a mini quadcopter kit with a frame size of 250 mm. The kit is unassembled. You may also purchase an assembled version which is a bit more expensive but you can still learn from it more easily if you are just a beginner. You will have to buy the radio transmitter separately. The prices are very reasonable. Four LHI MT2204 2300KV Motors comes with the kit with LHI 12A Brushless SimonK ECSs.  OpenPilot CC3D is the flight controller. The best part is that you can use opensource OpenPilot software on your tablet.
3. 3D IRIS+ Quadcopter Kit by 3DR
This is the best kit for beginners. The kit include all the required components and you just need to put them together. However, the gimbal is not in the kit. You can buy this as an add-on. Tarot is the recommended gimbal for this kit. The kit include the radio controller, , props, landing gear, telemetry module, cables and battery with battery charger. The telemetry antenna is attached and the frame is pre-assembled. You should order the proper (American or European) telemetry radio set when ordering the kit.  The flight controller is Pixhawk.
4. QAV250 Carbon Fiber Mini FPV Quadcopter Kit
This is a drone kit by Lumenier. QAV250 is a popular mini FPV quadcopter kit. The frame size is 250mm.  This G10 version is a carbon fiber version. It can accommodate 5" Props. For bigger 6” props, you need to buy QAV250 6" Carbon Fiber Arm Extensions.
 You can also buy QAV250 frame-only and then can add other components of your choice. You can also buy this drone on Amazon and getfpv websites. A good kit for beginners, it can save you time, and you can still play around and learn. The 250mm is the distance measured motor shaft to motor shaft diagonally. If you go for a frame-only option, the compatible motors would be light and sturdy Lumenier RX2206 2350kv motors.  You can also use GoPro camera instead of a Lumenier camera, you would need a QAV250 CF Vibration Damping Camera Plate. This will reduce the vibration by separating the camera plate from the air-frame and by absorbing vibration.
5. GB 190, Racing Drone kit by Gearbest
It is a full quadcopter kit. You just have to add a radio receiver which should be compatible with your radio transmitter. The kit has two versions, standard and racing. Here we discuss the racing version. The kit comes with an X frame, PDB, F3 flight controller, EMAX RS2205 motors (brushless), camera, props, ESCs, connectors, VTX and antenna and few other accessories. The price is very affordable. The camera is also included. The kit is very compact. Frame arms are mad of carbon fiber with one small structural component made of aluminum.
Want to Buy a Drone:
If you are interested in buying a drone, you may find the following articles useful on Personal Drones:
1. 4 Best Beginner Drones
2. 5 Affordable Drones with Camera
Comment by Auturgy on November 3, 2017 at 10:18am
This list may have been ok in 2013....but it’s 2017, and you are giving bad advice
Comment by Joe Buzz on November 4, 2017 at 10:06am
Agreed, there seems to be some old information. My website BuzzDrones has some updated models which are more user-friendly and will see you up in the air for more than a few seconds as the op suggested.
I always recommend using a technical sheet to analyze the benefits of your purchase, otherwise, it will fall short of your expectations upon arrival.
Comment by Tahir Yaqub on November 5, 2017 at 11:36pm
Nothing is old guys....and Old is gold
Comment by Tahir Yaqub on November 5, 2017 at 11:39pm
And Joe Buzz, It would be better to put the brand name on your website. No brand names just racing drone kits!...this looks suspicious to me.
Comment by OG on November 6, 2017 at 3:25am
sorry in today's drone market all the stuff you listed old JUNK! nothing is relevant today please take the time and do some home work ! you can not buy most that stuff out of stock so old inferior to new stuff!  your not the first to post bunch of old stuff wondering why what the motivation?
example of new!
Comment
