Hi Guys,
I received the OpenLRS PCBs and we start to working about firmwares.
This is the Tx module of OpenLRS, It gives 100mw 433mhz RF power and its penetrating behind 5-6 concrete building!, we will test it on flight for range. System can controllable by any PPM signal or over RS232(bidirectional)
This is the Rx of OpenLRS,
It is very small receiver that supporting I2C (for IMUNext) and RS232 Telemetry. It sends the RSSI level over telemetry and RSSI output (PWM).
And our killer 7W Booster for very long range oneway RC control.
All Atmega328 processors including MegaLoad bootloader for firmware update over rs232. All AVR programmers are welcome.
They will in stocks before 2011.
You can follow the OpenLRS project from here
Cheers and Mary Christmas
Melih
Comment by Melih Karakelle on December 25, 2010 at 3:47pm
Comment by Jhon on December 25, 2010 at 7:10pm
Comment by Russkel on December 25, 2010 at 7:50pm
Comment by Russkel on December 25, 2010 at 7:55pm
Comment by Melih Karakelle on December 26, 2010 at 4:07am @Jhon, the blank square for speaker ;) I'm using a speaker(not a buzzer) because of different frequency alerts etc. And you can see the pinouts for IMUnext that placed on right top side of Rx module (G,DA,CLK,3.3V) This pins supplying the stamp size 6DOF IMU and talking it with I2C protocol. I didnt design it for connect over Rx, because you should fix the IMU on CG point and it must be parallel to the earth. you need 4 wire for connection.
@Kamu, thanks for JR module links, i send the mail for 5 module producers and i'm waiting for replies. Module base versions less useful for DIY usages but i will think about that for plug and play RC users. HopeRF producing 500mW version of same modules but it is working with 12V and 3 times bigger than current ones.
Actually the OpenLRS project didnt focused on "long range" because it is illegal for %90 of the countries, current 20db (100mW) output power is enough for most of applications and we are focusing on telemetry and firmwares. You dont need Parallel PPM to Serial PPM converters / extra telemetry transmitters anymore. Just change the firmware and you got it.
I will share the codes and PCB design in few days.
Comment by Jhon on December 26, 2010 at 12:54pm
Comment by Renato Aranghelovici on December 26, 2010 at 1:02pm I wonder how a higher frequence transmitter could jam a lower one...
Probably you have read about harmonics, but these are exacty the oposite ;) the 3rd harmonic of 433Mhz could influence 1280MHz video , and not the reverse.
It's like saying that 5.8Ghz video could infuence 2.4Ghz RC ;)
Comment by Russkel on December 26, 2010 at 7:57pm
Comment by Jhon on December 26, 2010 at 9:37pm
Comment by Melih Karakelle on December 27, 2010 at 4:24am @Jhon, RF module already including 20+ component for filtering, i guess they are enough for most of case.
@Kamu, You cant compare it with other FPV LRS systems because other ones using one way transmission without telemetry and Trappy using 2W (on booster mode) transmitter. mean, you have 2W parasite source on the plane when using telemetry. I'm designing it for opensource receiver usages as onboard stabilization, telemetry, etc. For only "long range", you can choose the solution from other brands or use my booster.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.10 members
110 members
182 members
1289 members
140 members
Powered by
