36X 1080P drone zoom camera with object tracking and geotagging
Sky Eye-36SZ is a 3-axis high stabilized gimbal with 1080P 36X zoom camera for drone inspection,surveillance,search and rescue applications.The 36X zoom camera provides 1080P 30FPS full HD video streaming and up to 432X zoom capability,which will enable you to capture every detail in the air.High-performance 3-axis gimbal is using advanced FOC(field-oriented control) motor control technology which will enable you to get a 0.01 degree incredible precise control,so the gimbal will give you crystal clear and stable video footage.
Further more,Sky Eye-36SZ comes with powerful night vision capability.The camera sensor is very sensitive to IR light due to its super low illumination:0.0005lux@F1.5(black/white),0.005lux@F1.5(color),0lux(IR).Once the enviroment illumination is lower than 0lux,then the camera IR cut will be activated(also you can activate it manually via controller),which will enable you to observe objects clearly in the darkness.
There is one big feature for Sky Eye-36SZ is that it can be equipped with an Auto Object Track Module(AOTM),which will enable the pilot to track static/moving objects very easily.Further more,the AOTM is only 40 grams,do not add too much weight on the drone. How it works : put the object you want to track in the screen,move the cursor to the object and lock it via controller,and then the camera will track it automatically.
Another big feature for Sky Eye-36SZ is that the gimbal will geotag the video streaming and photos,also gimbal Yaw/Pitch angle,height,time information will be displayed on camera OSD,this is really important when you are conducting missions like rescue and search.
Sky Eye-36SZ provides an outstanding wiring hub design for RC receiver and video output port,which makes wiring pretty easy and clean.Also the gimbal offers 2 smart speed modes:FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick.LOW speed mode is used for large zoom range,will enable you to target the object more accurately.
Features:
1) 945grams,light weight
2) 1/1.9 inch 2.38MP CMOS sensor
3) 36X optical zoom,12X digital zoom,1080P/30 HDMI output
4) 1080P/30 H.264 video recorded for on-board TF card
5) Auto object tracking
6) Geotagging
7) PWM control and serial command control
8) Convenient wiring hub for RC receiver and video output
9) 3-aixs high stabilized gimbal system
10) Adjustable control speed: SLOW speed for large zoom range,accurate.FAST speed for small zoom range,sensitive and quick.
More details:
Click this link for more product details:http://www.yangdaonline.com/sky-eye-36sz-1080p-36x-zoom-camera-for-...
Product photos:
Comment by John McGrath on November 29, 2017 at 10:18pm
  1/1.9 inch sensor? Sorry not buying it till I see it on oh say a S1000 or Matrice with some smooth footage. What I see on your you tube is lots of jello on that gimbal. I realize that when you zoom in deep you might get some but you're selling a new product for 3K. The gimbal seems to not be dampening the vibrations. I have seen the DJI high end zoom camera (not Z3) and it does not act like this.  Best of luck.
Comment by yangdaonline on November 30, 2017 at 7:28am
Hi John,thanks for the comment.I have to admit that there is a little jello when you zoom in  to 36X,it is inevitably for a zoom camera.What mission do you plan to use the camera for?Please share it here if possible.
100KM
Comment by Hein du Plessis on November 30, 2017 at 3:14pm
Great for the money, can it be inverted?
Comment by yangdaonline on November 30, 2017 at 6:58pm
Dear Hein du Plessis,do you mean mount it upside down on fixed wing?
Yes,it can do that.
100KM
Comment by Hein du Plessis on December 6, 2017 at 3:33am
Thanks yangdaonline, how do you flip the image?
Comment by yangdaonline on December 6, 2017 at 7:36am
You need to go to the camera OSD menu with remote control and flip the image.
100KM
Comment by Hein du Plessis on December 6, 2017 at 3:01pm
Thanks, I've recently bought another version of this camera (FH318Z V2) , bought from foxtechfpv, but it does not have the flip menu item : https://youtu.be/IfoTL1TFaKs. Can you help?
Comment by yangdaonline on December 6, 2017 at 7:49pm
We supply the camera:http://www.yangdaonline.com/sky-eye-18hz-1080p-18x-optical-zoom-cam...
You need to go the General Setting,please check following photo
100KM
Comment by Hein du Plessis on December 6, 2017 at 11:59pm
Thanks is that the LCD rotate function? Great to know who supplies the camera!
Comment by yangdaonline on December 7, 2017 at 1:57am
Yes,LCD Rotate
Comment
