36X 1080P drone zoom camera with object tracking and geotagging
Sky Eye-36SZ is a 3-axis high stabilized gimbal with 1080P 36X zoom camera for drone inspection,surveillance,search and rescue applications.The 36X zoom camera provides 1080P 30FPS full HD video streaming and up to 432X zoom capability,which will enable you to capture every detail in the air.High-performance 3-axis gimbal is using advanced FOC(field-oriented control) motor control technology which will enable you to get a 0.01 degree incredible precise control,so the gimbal will give you crystal clear and stable video footage.
Further more,Sky Eye-36SZ comes with powerful night vision capability.The camera sensor is very sensitive to IR light due to its super low illumination:0.0005lux@F1.5(black/white),0.005lux@F1.5(color),0lux(IR).Once the enviroment illumination is lower than 0lux,then the camera IR cut will be activated(also you can activate it manually via controller),which will enable you to observe objects clearly in the darkness.
There is one big feature for Sky Eye-36SZ is that it can be equipped with an Auto Object Track Module(AOTM),which will enable the pilot to track static/moving objects very easily.Further more,the AOTM is only 40 grams,do not add too much weight on the drone. How it works : put the object you want to track in the screen,move the cursor to the object and lock it via controller,and then the camera will track it automatically.
Another big feature for Sky Eye-36SZ is that the gimbal will geotag the video streaming and photos,also gimbal Yaw/Pitch angle,height,time information will be displayed on camera OSD,this is really important when you are conducting missions like rescue and search.
Sky Eye-36SZ provides an outstanding wiring hub design for RC receiver and video output port,which makes wiring pretty easy and clean.Also the gimbal offers 2 smart speed modes:FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick.LOW speed mode is used for large zoom range,will enable you to target the object more accurately.
Features:
1) 945grams,light weight
2) 1/1.9 inch 2.38MP CMOS sensor
3) 36X optical zoom,12X digital zoom,1080P/30 HDMI output
4) 1080P/30 H.264 video recorded for on-board TF card
5) Auto object tracking
6) Geotagging
7) PWM control and serial command control
8) Convenient wiring hub for RC receiver and video output
9) 3-aixs high stabilized gimbal system
10) Adjustable control speed: SLOW speed for large zoom range,accurate.FAST speed for small zoom range,sensitive and quick.
More details:
Click this link for more product details:http://www.yangdaonline.com/sky-eye-36sz-1080p-36x-zoom-camera-for-...
Product photos:
100KM
Comment by Hein du Plessis on December 11, 2017 at 1:19am
Thanks again - this worked - I've tried it a number of times before, but it did not work until I restarted the camera, now it's perfect. Many thanks. BTW - do you have a "ball" version of this camera? The current version suffers wind pressure at high air speed (80km/h).
Comment by yangdaonline on December 12, 2017 at 1:29am
Yes,we have a ball version for the 18X 1080P zoom camera:http://www.yangdaonline.com/sky-eye-18hz-1080p-18x-optical-zoom-cam...
100KM
Comment by Hein du Plessis on January 12, 2018 at 6:51am
Hello, can I have your email address? I have a client that wants to know if it's possible for custom load-outs of the gimbal.
Many thanks.
Hein
Comment by yangdaonline on January 12, 2018 at 7:27am
Hello Hein,
My email address:info@yangdaonline.com
Comment
