Ground Control Station is a GUI based on GTK+, the platform is a quadrotor developed several GTK+ widgets capable of display telemetry data. These widgets are made to look like to real flight instruments in order to allow easy feedbacks for the user/pilot.
-Input Device 3D connexion 6Dof Mouse form manual navigation
-Automatic mode GoTo (coordinate selected on map click)
-Comunication Socket streaming UDP
-GUI Compatible for any Linux machine with GTK+ (Debian Ubuntu ...)
-HUD with Artificial Horizon
-Incorporate GPS map show
-Suppoert mjpeg streaming for augmented reality HUD
-Telemetry control
-Hhow inertial data
-Compatible UAV client FoxG20
The is the first version of the ground control station. In this version, the GUI is devided into 5 tabs. The first one showing the telemtry widgets needed. The second tab is quite the same as gpsd_viewer. The third tab provide an easy show UAV data, the fourth tab show the motor and battery status, and the final tab provide a set the comunication.
Comment by OlivierD. on January 26, 2011 at 12:27pm
Comment by SilverFox on January 26, 2011 at 12:30pm
Comment by Agustin Monteverdi on January 26, 2011 at 4:15pm amazing! seems to be very usefull and user friendly!
could u explain how toinstall it in arch or ubuntu?
is ther any way to have embembed the live video from the aircraft?
it would be nice to have a 3d model in a 3d map ,is there any way to integrate it to the google earth api?
Comment by Federico Lolli on January 27, 2011 at 1:56am
Hi guys,
yes,Acquiring images from a webcam on board autopilot(fox board g20 with arm9 cpu 400mhz http://www.acmesystems.it/foxg20/doku.php ),are sent via UDP,and finally appear in augmented reality in the UHD.
is not yet completed but soon I post everything on a quadcopter,I miss the place the code of the augmented stabilization sistem.
moreover, using a joystick as mouse 3d,
to manually control the UAV
to not use google maps, but instead osm-gps-map
when I tested and validated all code will insert new content and functionality.
seeking collaborators to help me, it's really a lot of work ...
p.s.(for now there is only the linux version.There is a small file to execute instructions in the package)
Comment by Federico Lolli on January 27, 2011 at 1:58am p.p.s. is designed for use with short-range helicopters and quadcoper
the imu is
Comment by Harald Sævold on January 27, 2011 at 4:58am
Comment by Russkel on January 27, 2011 at 9:59pm Wow looks good. The only simple improvement I can think of is replacing the word 'Battery' on the dial with a good old battery symbol.
http://www.lucasaide.com/prodimages/08102009104907Durite%20Pictures...
Comment by Krokodil on January 30, 2011 at 10:21am There is a similar groundstation for windows being developed for the ArduPiratesNG:
http://www.rcgroups.com/forums/showpost.php?p=17256578&postcoun...
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.58 members
24 members
1355 members
88 members
207 members
Powered by
