Inspired by John Arne's post, I got a Redcat Rockslide, which is totally cool and a great robotics platform. As you can see, it's really easy to add a mounting platform for electronics (that's APM with GPS and Xbee mounted above) and there's LOADS of room. You could even have it carry a laptop if you wanted. BTW, that's the 1/8 size Redcat shown above, which is $236. I think the 1/10 size Redcat would probably be just as good for most uses, and it's just $159. [Update: the 1:10 isn't big enough. See this comparison]
I've registered the ArduRover name, and am now just looking for the best starting point to modify the APM code for ground rovers. Since James Goppert is part of the APM dev team, we'll probably start with his rover code, which you can see at work here. But if others have code or sensor additions to the basic APM set that would be good to add to a rover, this is the place to discuss and share.
Ideally, we'll get this done in time for the Sparkfun AVC contest, on the hope that APM can have a decent chance of placing in all of the categories--ground, plane and quad. Which would be awesome.
Comment by Mathias on January 30, 2011 at 2:58am thats awesome!!
a hybrid where you control the wheel steering and yaw of the copter with the left stick left/right and with the right stick you control the cars accelerator/brake and the copter front/back/sideways. left stick front/back stays for copter up/down. would be great!
Mounting plates, sonar brackets etc will be made with cnc routers and laser cut. If people have few other good frame candidates on their mind. We could acquire few of them and make different mounting plates for those.
Both redcat frames will be supported at least.
@Johan, that frame is a beauty too ..
I just spent over an hour exploring my neighborhood. It is fascinating to see everything anew from a low to the ground perspective. Discovering nooks and corners I never bothered having a proper look at before.
The trip ended with a proper roll over with three complete turns breaking the UHF pcb antenna mount. My bad, the hill did not look that steep from the camera wide angle. But it shows that we need to look into how to best mount and protect the equipment. Some kind of flexible spring mount for the antennas etc.
Comment by Johann Van Niekerk on January 30, 2011 at 9:57am
Comment by Johann Van Niekerk on January 30, 2011 at 10:12am Think im going to order the ground pounder redcat, 1/10 scale and bit faster for flat terain.
I see that water, dust, mud all become factors now .... atleast if something breaks down we dont have that other bad word nocking on our door .......Gravity!
Comment by Johann Van Niekerk on January 30, 2011 at 10:53am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
203 members
24 members
207 members
58 members
Powered by
