I know, the world probably has enough flying machine projects, but here is yet another one. AutoQuad's original design goal was high precision autonomous flight. It took five prototypes before I was happy with the hardware. The current prototype, AQv5, is showing very promising results. In fact, there is little left to do before this first goal can be checked off the list. Using this as a solid base, I intend to continue research, design and experimentation toward vision based navigation for indoor and outdoor use.
Hardware:
- 2" x 2" board with same mounting pattern as the MK FC
- Input voltage ~7.5v => 18v
- High efficiency DC/DC converters
- STM32F103 32bit Cortex M3 microcontroller @72 MHZ
- standard ARM 20 pin JTAG header for real-time debugging
- up to 8 PWM ESC motor control (prefer Turnigy ESC's with custom firmware)
- 2 powered payload servo controllers
- optional ultra sonic range finder
- Spektrum satellite (remote receiver) 2.4Ghz RC radio
- uSD card slot
- optional onboard uBlox LEA-XX module w/battery backup & timepulse capture
- optional female SMA connector for active GPS antenna
- optional external GPS via standard 6 pin connector (EM406, EM401, uBlox, MTK)
- optional onboard xBee module - up to 300mA (2.4Ghz, 900Mhz, bluetooth, etc.)
- optional external radio via standard 6 pin FTDI connector - up to 1A
- I2C bus connector for I2C ESC's
- modular sensor board (SBv5) - 100% analog sensors, EMI hardening:
+ 3 axis acc (ADXL335)
+ 3 axis mag (HMC6042 & HMC1041Z)
+ 3 axis gyro (IDG500 & ISZ500)
+ 2 temperature sensors
+ pressure sensor (MPXH6101A)
+ battery voltage
Software:
- Fully threaded RTOS design written in C - 60% idle
- All sensors read at 113KHz (~1.4M sps total)
- 450Hz motor update rate
- 200Hz attitude, 3D velocity / position solutions
- Full downlink telemetry
- Detailed system state dumps @200Hz => uSD card w/FAT32 FS
- Quaternion based attitude filter additionally producing rotation matrix and Euler angle outputs
- All math in single precision floating point
- Temperature compensated and calibrated sensor suite
- Custom ground station software w/bi-directional command and control API
- Cascading PID control system, velocity based for smooth transitions
- Auto land / takeoff
- Hover position / altitude hold
- Autonomous waypoint mission navigation
- Precise altitude hold indoors
Example of current capabilities:
Design philosophy:
- High performance
- Efficiency
- Ease of development
- Consistency / Repeatability
- Low cost
There is always room for improvement. For instance, I would like to see how much of a benefit using a SPKF (Sigma Point Kalman Filter) would be over my fixed gain navigation filter. Looking forward to the new Cortex M4 uC's with a hardware FPU so that any such math intensive solution can be more easily handled. As I mentioned above, there is a lot of room for work with vision navigation and SLAM. Also interested in propulsion efficiencies which with an eye toward higher endurance. Although the PID based control system works extremely well, I'm interested in exploring different types of MPC (model predictive control) to reduce control costs and increase precision.
I'm wondering if there is anyone interested in joining forces to work on some of the above mentioned or anything else along these lines that presents itself. This is only a hobby for me and I currently have no profit motive. This is definitely not a beginner's project as you can see by my sloppy SMD hand soldering job.
Comments?
Comment by Maximus on February 9, 2011 at 8:59am Perfect ,Bill !!!
Can we use standard PWM ESCs ?
Maximus
Comment by Bill Nesbitt on February 9, 2011 at 9:07am Bill, what is the f factor in the derivative component?
| pid->dTerm_1 = (d * f) * (error - pid->dState); |
| pid->dState += f * (error - pid->dState) |
Comment by Bill Nesbitt on February 14, 2011 at 7:55am
Comment by Giovanni Esposito on February 14, 2011 at 9:22am Amazing work Bill, incredible results for a "one man only" hobby project! I can hear Holger Buss crying.... :-))
The board design is really nice, so small and integrated! The socket for the external sensor is very smart and using the new upcoming invensense imu and updated magnetometer and baro look easy...
Do you plan to make more boards, have some in stock to sell?
Comment by Maximus on February 14, 2011 at 11:30am
Comment by Bill Nesbitt on February 15, 2011 at 8:22am
Comment by Bill Nesbitt on February 15, 2011 at 1:10pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
7 members
87 members
131 members
47 members
Powered by
