I'm delighted to announce the release of the first public beta of ArduPilot Mega 2.0. This is a significant upgrade to APM 1.02, and now delivers on full 2-way in-air communications, including real-time mission planning and autopilot control.
[UPDATE:Arduino-free code uploading added to features]
New features/changes include:
--2-way telemetry. Dozens of commands can now be sent from the Ground Station to the UAV while it's in the air. (see example from HK GCS at right)---------------------------------------------------------------------------------------------
Huge props to the whole development team: Doug Weibel (project leader), Michael Smith, Jason Short, James Goppert, Michael Oborne (mission planner), Paul Mather (GCS), Lorenz Meier (MAVLink integration), Randy Mackay, Ryan Beall, Darren Corley, Joe Holdsworth, and countless others who have contributed with flight testing and bug catching!
Remember that this is an initial beta release, so there may be bugs and undocumented bits. After the beta-testing period (usually about six weeks) we'll release APM 2.0 final version, and retire APM 1.02.
Loading the code automatically:
Just download the Mission Planner and select "Upload Firmware" from the Tools section of the menu. Make sure APM is plugged into your USB port and you've selected the right port from the Mission Planner menu. Click on "Update Check" and the program will search online for the latest version of the code and load it to APM.
If you want to do a simulation with Xplane, follow the instructions below. That will soon be a firmware option with the Mission Planner, too.
Loading manually (Optional)
[UPDATE: Ignore this section if you don't want to fiddle with the code. Arduino is no longer required to load the code!]
Download the zip file, unzip it to your desktop. You will have two folders inside your APM 2.0 folder, as shown:
Make sure you're using the latest Arduino (0022). Set your Arduino Sketchbook location to the APM 2.0 folder, as shown below. You must exit Arduino and restart it for this to take effect. Within Arduino, open up the ArduPilotMega.pde file within the ArduPilotMega folder, and that will open all the other files. Before you compile, don't forget to select the right board (Arduino Mega 1280 or Arduino Mega 2560)
(Note: in the final version of APM 2.0, you will not have to use the Arduino IDE at all: the Mission Planner will load the firmware for you and check for more recent versions. The Arduino IDE will just be available in case you want to modify or inspect the code. UPDATE: this is now live)
Additional instructions:
--If you're doing flight simulation with Xplane, instructions for doing it with APM 2.0 are here.
--Make sure you're using the latest Mission Planner and HK GCS. In the Mission Planner, make sure you select APM 2.x modes (MAVLink), shown at right.
Known issues:
1) Mission Planner won't write waypoints on Port 0 in HIL mode. Instead, write the waypoints via your Xbee (port 3); remember to change the Mission Planner baud rate to 57k when using the Xbee port.
2) Uploading mission commands is still not fully documented. We'll get to that this week
3) There may be some issues with datalogs not recording. We're looking into it.
4) The manual still describes the 1.02 software. We'll change that to 2.0 during the beta test period, so by the time we release the final of 2.0 the manual is fully updated.
5) This has been mostly tested with 900 Mhz Xbee modules and the XstreamBee adapter, which work great. However, there is an issue with the 2.4 Ghz Xbee modules, which have a slightly different hardware configuration that conflicts with that adapter when sending data upstream. A short term workaround is to solder a jumper from the adapter's CTS to V+ pin. The next version of these adapter boards will include a more graceful fix.
If you find any bugs, please file a report in the Issue Tracker. The dev team will not be responding to bug reports filed in blog comments
Comment by Darren on March 14, 2011 at 2:16pm
Comment by luca on March 14, 2011 at 3:30pm
Comment by The Old Flyer on March 14, 2011 at 5:41pm 2.0 is great! I have downloaded it and checked out all the CLI interactions. The 'test > show' is fantastic.
But - I think I broke something.
I wanted to check out the Mission Planner (0.4.15. build 0.4.4089.13942) update firmware function.
I thought I had the com port set correctly. The terminal screen showed the download process but I accidentally closed the firmware update window and the process stopped.
Now my system is almost dead. The mux LED on the APM board blinks and RC/servo action is OK.
On the IMU board the blue power LED is on but there is no other action. I switch the slide switch from the CLI position, hit reset, and got NO serial communication. (The serial Monitor worked well before.)
I put the slide switch in 'fly' position, hit the reset and nothing happens. No flashing lights - nothing.
Now what should I do?
Thanks.
Comment by The Old Flyer on March 14, 2011 at 6:15pm Thanks for the quick response. I was afraid I had messed up the boot loader.
Any advice on which AVR method I should try? I don't have an AVR programmer but I do have an FTDI cable.
Comment by Darren on March 14, 2011 at 6:40pm FYI you must be in fly mode and have the proper com and baud rate selcted for USB port for the APM Planner uploader to work.
Else the Arduino uploader works at any selected baud rate, just as long as the right com port is selected.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.42 members
126 members
24 members
51 members
87 members
Powered by
