Maybe someone has encountered a small scale parachute ?
I'd like to add a safety parachute to the Arducopter !! help me decide....
As part of the project is to use an expensive DSLR on the copter,
My GF said i must have some kind of emergency parachute... after joking at it, i thought deeper -
I'd rather feel much safer having a parachute as backup to all electronics (even though i plan on 6 or 8 motors)
Just imagine an emergency button that will immediately turn off all motors and shoot a parachute.
questions:
as parachute takes some time to open (=some free fall height), the benefits are sure and obvious for a 100m fall.
but if i'm around 5m above ground, (which can still be nasty to the DSLR) - would i have enough "falling time" to open the parachute and having enough braking force ?
think i better make one by myself ? is it rather simple as cutting and connecting wires to a cloth,
or it is more complex design that i could hardly achieve and i better get a ready one ?
i came across this as the only parachute i could find:
http://cgi.ebay.com/NEW-40-SPEED-RUNNING-POWER-CHUTE-training-parac...
It looks sturdy and well balanced & stuff... it's totally affordable !
they say the 40" version has 7KG resistance. i'm safe on this side, i dont want a much bigger one.
how about the opening technique ?
i could stuff it in a small plastic tube attached to the top of the dome, using a small solenoid or servo to kick it out...
how do i ensure it opens reliably ? i guess it depends on the folding inside the storage tube...
Comment by ARHEXA on March 28, 2011 at 5:24am exactly,
this video is exactly the opposite of any common sense design...
now to some experienced user question -
If i disconnect the power of the APM/IMU/TX all together off the BEC, in the middle of a flight while motors running,
but the ESC's are still connected to the battery - what will happen ?
(in other words what happen when you unplug an ESC signal cable while running)
hopefully this will stop the motors, that way i can put a relay to disconnect the 5v electronics, rather than having to use a very high amperage relay to disconnect ESC's off the LIPO....
Comment by ARHEXA on March 28, 2011 at 5:29am Here i found a successful one, @ 0:40
you could also send 0% throttle to the ESCs instead of disconecting them.
With no signal, and ESC not having any failsafe function, should stop
Comment by Martin Seven on March 28, 2011 at 5:33am
Comment by Martin Seven on March 28, 2011 at 5:36am
Comment by ARHEXA on March 28, 2011 at 5:36am for sending 0% throttle i have to use the copter code, and at the moment of truth i rely on the electronics.
if the quad fails because of the electronics, i cant use the software to turn off the motors...
i must have an aggressive and simple way to switch to emergency state, like disconnecting the motors or the APM
Comment by Martin Seven on March 28, 2011 at 5:52am
Comment by ARHEXA on March 28, 2011 at 5:55am I think of getting this one.
http://cgi.ebay.com/48-Red-Model-Rocket-Parachute-Quality-Rip-Stop-...
the description says 'slow descend' for 1.5kg and moderate speed descend with ~2kg...
my copter will be more than 2kg, so i think there's no chance i'll try some smaller than 48"....
on the same hand, i hope 48" will be enough...
Comment by ARHEXA on March 28, 2011 at 5:59am @Martin-
right, but then i have to add 4 small relays (or 2 double pole) to switch the signal off the APM.
i've seen a warning somewhere to NEVER disconnect an ESC from the APM while running. (that could damage APM)
I really prefer the electronics disconnecting option...
i guess i will have to experiment what happens to the ESC in that case...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.15 members
50 members
247 members
106 members
1279 members
Powered by
