Maybe someone has encountered a small scale parachute ?
I'd like to add a safety parachute to the Arducopter !! help me decide....
As part of the project is to use an expensive DSLR on the copter,
My GF said i must have some kind of emergency parachute... after joking at it, i thought deeper -
I'd rather feel much safer having a parachute as backup to all electronics (even though i plan on 6 or 8 motors)
Just imagine an emergency button that will immediately turn off all motors and shoot a parachute.
questions:
as parachute takes some time to open (=some free fall height), the benefits are sure and obvious for a 100m fall.
but if i'm around 5m above ground, (which can still be nasty to the DSLR) - would i have enough "falling time" to open the parachute and having enough braking force ?
think i better make one by myself ? is it rather simple as cutting and connecting wires to a cloth,
or it is more complex design that i could hardly achieve and i better get a ready one ?
i came across this as the only parachute i could find:
http://cgi.ebay.com/NEW-40-SPEED-RUNNING-POWER-CHUTE-training-parac...
It looks sturdy and well balanced & stuff... it's totally affordable !
they say the 40" version has 7KG resistance. i'm safe on this side, i dont want a much bigger one.
how about the opening technique ?
i could stuff it in a small plastic tube attached to the top of the dome, using a small solenoid or servo to kick it out...
how do i ensure it opens reliably ? i guess it depends on the folding inside the storage tube...
Comment by Jerry Rodberg on March 28, 2011 at 1:21pm
Comment by ARHEXA on March 28, 2011 at 1:38pm mmm, this might be a bit too far...
the camera mount and landing gear around it will be made of thick aluminum tubes, i think it's a good protection, even if they bent a little, there still will be room before hitting the camera. and yes i can add foam....
anyways, i'm not aiming to save only the copter,
why not saving BOTH at once with a single parachute...?
after all the copter costs like 1/2 the DSLR....
what i've got to keep is an option to disable it totally - even if it's 100% manual.
if i'm flying near the sea or a lake, i'd prefer it smashed on the ground rather than drown in the water....
Chutes used in High Power rocketry might be an option, I'd also look at a mesh parachute (mesh on the bottom instead of lines), just to avoid tangling issues with all the rotors. As for deployment speed, without a forceful deployment you will have drop before it opens, you could use a power deployment with a cardboard tube (which then helps clear props too) ala HP Rocketry (usually a small BP charge). But I wouldn't do that without looking at the potential regulartory issues. A spring/piston might be a better choice....
Perhaps you can also reduce reaction time with a deadman switch stick that you just drop if things go bad. Probably faster than fumbling for a toggle anyway. You'd need to enable aggressive and active breaking on your ESC's to stop the props in time, not sure that's worth it.
Comment by Martin Seven on March 29, 2011 at 2:59pm
Comment by ARHEXA on March 29, 2011 at 11:28pm I see,
breaking is an option. i hope it won't affect with very high torque resulting in yaw or flip over... (remember one motor is probably gonna be dead)
Yesterday i tested what happens when you disconnect the ESC while motor is running:
it was a generic ESC (not arducopter), when i disconnected the signal it started to jump between 0 throttle and the throttle it was left on, randomly.
though maybe connecting the signal line directly to ground might tell the ESC to stop also - have to check.
so for active breaking i have to put relays on the ESC's signal lines that will take the signal away from the APM, and connect all together to a servo tester outputting "0" throttle.
that's not too hard.
Comment by Martin Seven on March 30, 2011 at 12:55am
Comment by ARHEXA on March 30, 2011 at 12:57am i can understand that,
just tested a 80A 100mm EDF yesterday !
Comment by Chris Card on April 1, 2011 at 8:03pm Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
48 members
693 members
51 members
249 members
Powered by
